Please. Help me find my drain plug!
Old Oct 18, 2009 | 11:04 PM
mred589's Avatar
I can't seem to find it on my truck. I've seen pictures of where it's supposed to be, and when I went to look, it's not there..... Does anyone know why?
Is the 4.6 drain plug in a different spot?
Do I have a different engine?
I'm kinda stuck right now, any help would be great.
EDIT: I am looking for the Coolant drain plug, not the oil drain plug.
Old Oct 18, 2009 | 11:05 PM
Camarothatcould's Avatar
do we know what an oil pan is?
Old Oct 18, 2009 | 11:20 PM
should be at the lowest point on the oil pan
Old Oct 18, 2009 | 11:26 PM
mred589's Avatar
Sorry, I was so frustrated, I forgot to specify. I need the COOLANT drain plug, NOT the oil plug. Sorry for the confusion.
to camarothatcould: Yes, I know what an oil pan is, I've changed my oil many times.
Old Oct 18, 2009 | 11:28 PM
coolant drain is on the lower passenger side of radiator if you have one. If not take the lower radiator hose loose from which ever end is easier for you to take loose
well, its plastic, and most likely will break.... but its at the lowest point on right side of truck.... it splashes coolant onto the frame and all over...
Old Oct 18, 2009 | 11:37 PM
mred589's Avatar
Wow, I must be really annoyed. Time to count to 10...................1.....2....3....45678910
OK. Lets start from the beginning, I'm trying to drain all of the coolant out of my truck. I've already drained the radiator from the small plastic nozzle on the passenger side, but I know that isn't all of it, the block still has antifreeze in it. I'm trying to find the plug that everyone seems to think is next to the last freeze plug on the drivers side. I'm looking at the spot, and it's not there. I have a picture of exactly what it should look like, and mine matches exactly (tranny bolts, bushings, other assorted bolts) except that I have no drain plug.
What gives?
Old Oct 18, 2009 | 11:48 PM
ive never heard of a block drain plug on any car
Old Oct 18, 2009 | 11:59 PM
robbinsresort's Avatar
On my 5.4 it was on the drivers side below the exhaust manifold. Did mine last week. This thread might help you ---> https://www.f150online.com/forums/ar...ntifreeze.html
Specific post in thread referring to block drain plug ---> https://www.f150online.com/forums/3887211-post10.html
Old Oct 19, 2009 | 12:10 AM
mred589's Avatar
That is the exact picture I looked at. I had to check 4 times, but I don't see a drain plug there.
Old Oct 19, 2009 | 02:32 AM
code58's Avatar
On a V type engine (of any # of cylinders) you should have a drain plug on BOTH banks. May not necessarily be easy to find but I am not familiar with one that DOESN'T have drain provision for the complete block.
Old Oct 19, 2009 | 02:39 AM
code58's Avatar
Hard of hearing Patman? JK Every car or truck I have had has had drain plugs (or plug in the case of 4 Cyl) for the block because I always believe in draining the block also.
Old Oct 19, 2009 | 03:17 AM
Paralyzer's Avatar
forget the block drain plugs!..here is what you do to do a coolant flush.(if you like you may add a cooland flush solvent and bring up to temp before draining coolant). First drain the radiator, second remove the thermostat and o-ring and reassemble without them, third remove the upper radiator hose from the radiator and point it into large pail. Now....put a garden hose in the radiator opening where the upper rad hose used to be, turn the hose on full blast and start your truck. water/coolant will start pumping out the upper rad hose into the bucket. once the bucket is full just let it pump on to the ground as almost all the coolant will be out by now, do this for 5 minutes or so. Flush finished, turn off hose but let truck continue to run till water stops pumping out. NOW reinstall thermostat(preferably a new one) and reattatch the upper rad hose. Fill up system with STRAIT coolant(keep in mind block is full of water). Drive vehicle untill thermostat opens and check coolant strength/ correct as needed. It is usually close to 50/50 as desighn a radiator is always half the coolant capacity. DONE.
Old Oct 19, 2009 | 05:51 AM
Or, you could use one of those Prestone flushing tee kits.
Old Oct 19, 2009 | 02:29 PM
AZTriton's Avatar
Or save yourself a lot of frustration and time and go to a shop and have them flush it. It's about $100 and worth the price if you ask me.
