Can i stroke my 5.4?
Old Oct 2, 2009 | 09:55 PM
FRod's Avatar
So more ideas roaming my brain (not good). I recenetly did some headwork, cams, valves, porting ect, to my 5.4. But since it is torn apart, I want to make it a stroker, as ive stroked a 460 before. Ive been reading that Fords future 5.0 is a stroked 4.6 and the 6.2L Boss is just a stroked 5.4, but im not sure if the internals are forged, or if these rumors are even true. I am trying to find a stroker kit but cannot find anything, only the 4.6 to 5.0 kits. (newbie when it comes to finding stuff on the internet)
My question is, where can i locate a stroker kit, OR should i be looking for the 6.2 rotating assembly?
Old Oct 2, 2009 | 10:43 PM
bozak1's Avatar
there is a stroker kit at paschalperformance.com. little pricy. The new 6.2 is definately not a stroker 5.4. different motor. the 5.4 is an oversquare motor so its hard to stroke it anymore than it already is while retaining reliability, I looked into this to and that is what i was told anyway.
Old Oct 4, 2009 | 04:54 PM
Veteran: Army
paschal says there is nothing wrong with the reliability of their 6.2 kit unless you rev it over 6,000rpms
Old Oct 4, 2009 | 09:29 PM
minimonster17's Avatar
i believe the paschal kit includes forged internals, too.
Old Oct 6, 2009 | 12:13 AM
FRod's Avatar
there are 2 kits available it appears, a billiet and forged metal. I would go with forged. The kit is $2,000 forged pistons and crank, steal rods bearings seals, which is NOT bad in my book. I am strongly thinking about this. Would just need to get an oil pump and the block acid dipped and honed. What type of horsepower do you think i would make minimonster? with ported heads and stage 2 cams, and plus my description. I just gotta know that it would be worth it.
Old Oct 6, 2009 | 05:54 AM
Veteran: Army
Clifford told me about 100HP and FT LBS
Old Oct 6, 2009 | 05:19 PM
Roadie's Avatar
I'm pretty sure that the 5.4L engine is a stroked 4.6L
Old Oct 6, 2009 | 06:58 PM
phil6608's Avatar
Why stroke it when you can get blown?
Phil
Old Oct 7, 2009 | 02:47 AM
OrdnanceCorps's Avatar
I dont want to sound dumb -- But I am with this topic. But, isn't engine stroke just longer piston motion from the crack ? Changes things like compression and so on?
So unless these comments are sarcasm which I am missing how can a 4.6 be a stroked 5.4? As they're a displacements?
Old Oct 7, 2009 | 03:32 AM
Veteran: Army
I'm pretty sure it's not
a stroked 4.6 usually ends being either a 5.0 or 5.1 as the block is too narrow for the longer stroke of the stock 5.4
Old Oct 7, 2009 | 12:04 PM
4.6 Punisher's Avatar
Going on what that website you posted, you can stroke a 4.6 to a 5.4, but it take some serious block machining. Best to keep the 281 in the 5.0-5.1 range like you say.
Old Oct 7, 2009 | 12:46 PM
Put some serious strain going up a dang near whole litre.
Old Oct 7, 2009 | 07:40 PM
FRod's Avatar
the piston length is shorter making a bigger longer stroke. The 5.4 is a mild stroked 4.6 technically. The 4.6s bore is 3.55 and the stroke is 3.54, and the 5.4s bore is 3.55 but the stroke is 4.16. Thats all i can tell based on specs i got off this website.
http://www.fordf150.net/specs/02f150.php. I just need to find a $1200 kit and im gonna do it!
Phil - Couldnt i still throw a blower on a stroker motor? I cant fund for that but someday. And i plan on keeping this truck for a long long time.
Old Oct 7, 2009 | 09:32 PM
In order to handle the longer stroke, the 5.4 has a taller block if I'm not mistaken.
Old Oct 7, 2009 | 11:05 PM
phil6608's Avatar
Yes you can. But a stroked motor will not last a long long time in a daily driver street truck.
Unfortunately you shouldn't believe the BS about the stroker not affecting the longevity of the life of the motor. It will!
The piston is pulled so far down in the cylinder that it will actually wobble in there. Causing excessive ware on the piston and cylinder walls.
I have thought about it myself only to be talked out of it by numerous people that have been around and know what there talking about.
Phil
