Loss of power-What order to replace things?(4.6L)
Hi Guys,
My 04 4.6L is feeling sluggish. Like I'm having to give it more throttle than normal, & MPG's are down of course. I've been running mid-grade (89?) octane gas, (which the truck runs much better on than reg.) for the last 30K miles, I'm at 67K now.
I run Mobil 1 Synthetic, air cleaner is new, 1 new COP (rear drivers #8?), still on original plugs, tranny fluid/filter replaced at 30K, nothing binding with the brakes.
My question is in what order should I look at, or replace the following?
* Plugs
* MAF sensor
* Oxygen sensor
* Cat Converters
* Injectors
I'm leaning towards having my mech clean the injectors. He claims it will help, he connects up to the fuel rails and runs some kind of cleaner through under pressure or something.
What do you think?
Thanks, MB
* Plugs
* MAF sensor
* Oxygen sensor
* Cat Converters
* Injectors
What do you think?
Thanks, MB
First thing on my list would be to change the plugs. I changed my 04 4.6 at 83,000 miles because it was sluggish and losing fuel mileage. I had plugs in the engine that had gaps at .074. I'm impressed it even started. I put Autolite Double Platinums in mine and power came back as well as mileage. And while yer working on it, might as well clean the MAF and change the PCV. DO NOT use any anti sieze on these plugs. USE LOTS of di-electric grease on the boots where it covers the porcelain part of the plug. Take yer time and buy LOTS of beer.
Labnerd, or anyone....(thank you all for the tips)
Do I need to worry about breaking plugs in the 4.6, or is that just a problem with the 5.4 3v?
Do you know the proper torque?
Will I have to remove the fuel rails?
Any TSB's on replacing them?
Thanks, MB
BTW...the fuel filter was replaced at around 30K, I guess I'll be doing it again.
Thanks, MB
Thanks, MB
Thanks, MB
hope this helps
that was taken after i let it sit for an hour or so.
we recommend 20k miles for fuel filter replacement, but it mainly depends on where you are and what kind of gas and what not. i've been in mooreville nc for about a year now and i changed my fuel filter with less than 10,000 miles on it and uhhh.... this is what came out
and x2 with glc's post
My original pump went out @ 90,000 miles, this one has 170,000 on it lol.
Yea, Motorcraft plugs definitely!! I dropped the tank last winter when I ran new hard lines for the brakes. Cleaned the tank and the fuel pump sock. Tank was dirty, wiped it out the tank and there was still allot of dirt/sand grains inside. Had to use Paint prep and a few clean rags to get all that out. The pump sock is detachable, but a PITA to clean well. It's better just to replace the sock. They get really dirty after a few years.
