Pats?
Old Sep 7, 2009 | 09:01 PM
fritz4077's Avatar
Pats?
i put a lightning motor in my truck...i got a pcm that came out of a lightning..its all plugged in...when i turn the key on the theft light blinks does that mean i have to take it to the dealer....i cant start the truck cause im still working on it
Old Sep 7, 2009 | 09:09 PM
torkum's Avatar
Can you get the key and ignition switch from the donor truck? If not take it to the dealer.
Old Sep 7, 2009 | 09:11 PM
K-Mac Attack's Avatar
You will need the GEM module too!
Old Sep 7, 2009 | 09:25 PM
fritz4077's Avatar
so basically i have pats and have to take it to the dealer...
Old Sep 7, 2009 | 10:38 PM
You will need the ECM reflashed. Hopefully all of the parts you installed match up otherwise so you have a functional truck with the gauges.
Old Sep 8, 2009 | 12:22 AM
fritz4077's Avatar
what do you mean match up...
Old Sep 8, 2009 | 12:29 AM
Hopefully the pcm from the lightning will control the trans...that would be the greatest concern.
Old Sep 8, 2009 | 12:58 AM
fritz4077's Avatar
it will i got a 4r100 tranny...
Old Sep 8, 2009 | 01:02 AM
yes get it towed to the dealer
Old Sep 8, 2009 | 01:13 AM
fritz4077's Avatar
what if u get a custom tuner will i herd that will take it off
Old Sep 8, 2009 | 08:39 AM
yes you can turn PATS off with custom tunes, but it kinda defeats the purpose of having it as an anti theft feature if you just go and delete it
Old Sep 8, 2009 | 09:07 AM
JMC's Avatar
JMC
25 Year Member
I would have the PATS turned off. PATS will only deter joy riders. As most cars today have some form of PATS most joy riders stay away from them. Anyone with an auto start feature is as much at risk as a non PATS vehicle. I had my PATS turned off for a while till I was able to fix my PCM. See; https://www.f150online.com/forums/el...roken-pcm.html
Old Sep 8, 2009 | 10:32 AM
fritz4077's Avatar
can i just take the ecm to the dealer and have them flash it...or do i really need the whole truck towed there
Old Sep 8, 2009 | 11:00 AM
JMC's Avatar
JMC
25 Year Member
The PCM needs to be installed in the truck it will be used in. The Dealer then programs the PCM and the Instrument cluster to work together.
Regards
Jean Marc Chartier
Old Sep 8, 2009 | 11:37 AM
fritz4077's Avatar
will the truck start or does it all have to do with the guages so i can drive it over there.
