bearing type noise
Old Sep 1, 2009 | 05:54 PM
Bubbadewsky's Avatar
bearing type noise
I have a 2000 5.4 f-150 and there is a bearing type noise that sounds like it is comming from the upper dash around the radio. It sounds like an idler pulley but with the serpentine belt off the noise is still there. It changes pitch with engine RPM, it can't be heard under the hood. Ford garage said it could be exhaust tube noise or torque converter..... they want $80 to check out. Any ideas appreciated
Old Sep 2, 2009 | 12:23 PM
DYNOTECH's Avatar
There are different kinds of bearings that make different noises. A rod or crank bearing will sound like a tapping/knocking noise when failing. A sealed or roller bearing will usually give a squeeling noise when it starts to fail. Depends on what you are hearing that can help us point you in the right direction.
Old Sep 2, 2009 | 03:08 PM
Matts ford's Avatar
cant be heard from under the hood? how about underneath the truck? is there any smoke? how many miles? have you checked your oil level? when was the last time it was changed? is it automatic or manual? and yea we need to know what kind of bearing noise your hearing.
