Performance coil packs
Good one man! - Well, I know what you meant. ~ I guess that's what puts me the "smart" side of that. Sorry for your luck.
There is absolutely nothing wrong with the cops that Ford sells, but it seems to me the price for ONE of them is about the same as a FULL SET OF 8 from the mentioned Ebay sellers - and the ones on Ebay have a LIFETIME WARRANTY - which the ones from Ford do NOT.
I think ist's following me , or somethin ...? - But yea ,- so will your Wallet. Global Automotive sells THE SAME coils (COP systems only) that Motorcraft does. The SAME, exactly the same coil markings boots and hot stamped. - The difference is the price and warranty.
UneekSupply is a fairly new at this, but I've heard that they sell the OEM's as well. I haven't confirmed Uneeks personally myself, however, this info came from a reliable source.
All you have to do is type "Misfire" or any of these -PO307, PO304, PO305, CEL Flashing in the "ENGINE" forum (only) under tools and you'll get confirmation.
The odds of all 8 going bad at one time and leaving you stranded are astronomical. Unless your truck burns up or gets hit by lightning or something...
If you are not having problems with your stock coils, then why would you change them? I'm still running my originals at 300,000++ miles. COP's are something that doesn't fall under preventative maintenance like changing your fan belt. Besides, you will get a CEL if one goes bad (same as O2 sensors). Then change it.
changing out the coils really isnt that expensive and it just makes sense.
You can throw money at anything, but it doesn't necessairly make it better. Especially somthing that isn't prone to failure, and has 7 backups. But if it makes you sleep better, I guess its $70 well spent.
The dealer dosent need to take off the drive shaft to replace the spark plugs and nor the steering wheel. Plus you factor in the parts the dealer wants you to replace that COME on a new set of coils.
Why not replace your drive shaft and your steering wheel too while you're at it. That makes about as much sense to me.
