New engine - fuel probs
Old Aug 12, 2009 | 09:31 AM
  #31
Jackrabbit396's Avatar
Originally Posted by Tumba
It says fuse #30 should be hot in run and start. @ junction box fuse relay panel.(so this fuse should no voltage with key off)
Fuse 30 in fuse relay panel chesks out as you said.
Fuse #30 red/light green wire, leads through the pcm power diode, and into the pcm ground, and Another wire in parallel to the ignition switch .
<The diagram shows the diode to be in line outside the PCM.>
The diode has measurable resistance, so it checks out i guess.
Fuse # 24 hot at all times in the power distribution box.(both sides of fuse hot at all times)
#24 in power box is always hot.
Wire from fuse 24 wire NCA(I don't know what color that is) leads to the pcm power relay.
I swapped the relay with the horn relay, so it is good.
and the engine fuse module, in parallel. The wire should be yellow and black. The wire continues from there ( black and light green) to thefuel injector ground.
does anybody know where I can check this ground?
Jbrew, no pulse on the noid. not sure about whether there is hot or ground to the injectors, but the light doesn't come on at all, nor does it pulse.
Old Aug 12, 2009 | 10:43 AM
  #32
Tumba's Avatar
Just for grins, use you test light on both sides of the inertia switch.
It is inside the kick panel, by the passengers foot. If you've got power on both sides, skip to the power line going to the pump.
Old Aug 12, 2009 | 12:33 PM
  #33
JMC's Avatar
JMC
25 Year Member
Your fuel injectors have 12 volts continuous when the key is on. That is the red wire. The PCM grounds the injectors to fire them. The PCM knows when to fire them when it gets feed back from the cam sensor. The plugs are fired by the PCM using signals from the crank sensor. There is a 5 amp fuse in Engine Fuse Module. That is the little rectangular fuse box next to the main one in the engine compartment. Check to see if it is burnt.
Old Aug 13, 2009 | 12:04 PM
  #34
and the winner is....
Originally Posted by DYNOTECH
No disrespect but I hope the HDR wheel was not reinstalled backwards...it happens. Good luck
Not only was it not installed correctly. It was not installed at all. I figured stuff like that was part of the long block. I guess that's what I get for not carefully checking over everything and asking enough questions before slapping the covers on.
Thanks to everyone!!!
