Wiring up E-fan
Are we talking about this dual fan controller?
http://www.jegs.com/InstallationInst.../555-10569.pdf
You could wire them up using that 2nd diagram (post #25). The main fuse would be 25A for 2 9A motors.
Or you could use the 1st diagram & wire one fan to the Lo relay, & the other to the Hi. That would also allow you to wire the Hi relay to the A/C clutch, making it the A/C fan the way you want.
