New Throttle cable
Old Aug 7, 2009 | 11:13 PM
b-ryan's Avatar
New Throttle cable
so i pulled off the cover for the throttle cable a couple day ago and saw that the cable that has 7 wires twisted to make the cable 5 of them were broke so i finly went to ford after seaching all over for a new cable and bought one $0 bucks for that cable is redictioul and even more is they wanted $150 to install it so im installing it tomorrow morining
does any one have any suggestions or tricks on how this should be done cause i have little clue on how to do this
thanks
Old Aug 8, 2009 | 11:36 AM
Matts ford's Avatar
you unhook it from the top of the pedal. then take out the 2 bolts that mounts the cable to the bulkhead. slide the cable out and then pull it off the bracket on the throttle body end. then unhook it from the throttle body and its off. its pretty straight forward.
Old Aug 8, 2009 | 01:45 PM
Camarothatcould's Avatar
cheesy
Old Aug 8, 2009 | 01:49 PM
b-ryan's Avatar
well i finished replacing it and it was straight forward thanks for the input
