Truck Lagging... Time to trade in?
Well the temp here today is 100. I am running my A/C and my truck is lagging HORRIBLY! When i was pulling out of the drive thru I floored it and it seemed to take its time to get up and going. Normally it would throw it in high gear and haul. I can't figure out what the problem.
I have a 2001 Supercrew with 125000 miles.
Does this mean its time to trade it in?
The problem does not exist when i don't run the A/C.
How many miles on your plugs, coils, and fuel filter? Got 118,000 on my 01 screw, and the AC doesn't make a whole lot of differance when its on. If Im towing, thats another story, but it will still down shift and try to do something. All comes down to regular mantanance, especially when trying to milk power from a 4.6
Trade it in, -who's knows, maybe someone willing to give her a little time can benefit from it. This way,- you can find another to run into the ground.
Yep... Lots of guys running these truck with WAY more miles then that. Trade it in. That will solve your problems till the next one gets some miles on it..
is it lagging only with the a/c on? what brand plugs did you use? i'm sure it just needs some sensors cleaned. clean the maf and throttle body. how old/dirty is the air filter? how old are the front o2 sensors?
Cats? Take it to a muffler shop and they can use an infrared probe to check for clogging.
Have you scanned the OBD2 for trouble codes? If the CEL has ever come on, there should be stored codes.
Does it lag every time you use the AC or just that once? Sitting in a drive through will heat soak the engine. With the AC on it will make it worse. The condenser is trying to shed the heat of the AC system and it sits in front of the rad. The fact that it doesn't do it with the AC off should point to a problem with the AC. Does it lag on the highway with the AC on?
glc: I have never heard of that. I will try to get some time to get over to the shop to try that. The CEL has only come on once in its life. That was when I forgot to hook up that Air Intake Temp Sensor when I was changing the intake back to stock.
JMC: Yes, it lags every time i use the AC. It does it worse when I am sitting at a stop then take off. I don't notice it so much when I am already up to speed.
