Best Price for Coils? Any package/kits?
Does anyone know the BEST bang for your buck on COP set?? The ones on eBay are $230 for the Accel ones. Are these any good??? Is there a place that sells a kit (with plugs/grease)???
Thanks (in advance)
Thanks (in advance)
We have the same year and engine. Do a search on this forum and there is alot of info on how to change the plugs and COP's. There are some specific's you should follow with the 98 5.4L V8. Not to bad of a job, done it twice now. You might want to look into Ebay, and check out Uneeksupply. I haven't heard of anything negative about their coils on this site.
Here is a current auction for them......
http://cgi.ebay.com/ebaymotors/NEW-I...1%7C240%3A1318
Good luck with plug change.
TJK
TJK
x2 on uneeksuppy
get a piece of hose to slide around the outside of the spark plug so you can thread the plug in without cross threading them. other than that torque them to 28 ftlbs and you'll be good.
Make sure you use Dielectric compound (grease) in the boots on the Coils. Thin to medium film on the entire boot inside and don't let a gob of grease plug up the end of the boot and spring end.
28 ft lbs is good advice, somone told me 30, so I went with that.
No problems at all since I did my own replacment.
Why no anti-seize?
Dam, I just paid $69.95 for ONE Standard Ignition COP
I believe S. I. to be good products, but $560.00 vs. $80 from Uneeksupply!
How good is the quality of the cheaper ones?
Thanks, Marc
Thanks, Marc
we say no antiseize because it changes how tight you torqued the plug and it helps the plugs back out which causes the blow out problems. i think they are almost the exact same thing as the factory coils, or they are the same(cant remember), that or they are very good at making it almost the exact same.
