Rough Idol/misfire?
Rough Idol/misfire?
I am experiencing a hesitation/intermitent rough idol. Seems to do it more when the A/C is turned on. Didn't make any recent changes to the truck that would cause issue, it just started happening. It usually only does it when I am at a stop light. I will be at idol just fine then the truck will sputter/hestitate/run rough for about 3 seconds, then go back to a normal idol. Sometimes it will just happen once, sometimes it is frequent. Here are the specs:
2002 KR Screw with 5.4l
k&n air filter
Granatelli COP's
Motorcraft plugs
Magnaflow exhaust
Xcaliber 3...still waiting on custom tunes
Truck worked fine when I changed the COP's and plugs. I have been running it for about 1,000 miles with that change.
I have no engine diagnostic codes that come up and all the COP's test well. The mechanic is stumped.
Any thoughts?
k&n air filter
Granatelli COP's
Motorcraft plugs
Magnaflow exhaust
Any thoughts?
