Bank 1 cesor 1 heat circut
Heater circuit Malfunction is usually a connector or wiring problem. Can be the O2 itself. Wires are very sensitive.
Passenger side harness takes a beating when the heater core hoses start to leak.
cool thanks guys i think i will go buy another o2 today change out the driver side one i put in take it back get a warenty replacment come home and change the passenger side then i will have changed them both at once clear the codes see what happens. glad somone told me i was changing the wrong side the jerk offs at autozone told me it was driverside for sure i will change them out check the wirers and update u guys later today
No no, just install the old drivers side into the passenger side. Life just got easier. Well, until you try to remove the passenger side lol. You'll find out why soon.
I'll even make that easier 4 yuh. Start off by removing passenger side wheel/ then inner fender liner/ then O2.
weel guys gave up on my original plan just bought a new sensor came home took off the old installed the new. A lesson i lerned last time (there is no subsitute for a 22mm wrench) just reached up next to the heat sheild from under the truck got the wrench at just the right angle (open end) broke losse with one grunting push. Stuck a small flat head up into the conector under the latching top piece pushing down the latch itself thats on the bottom piece grabed the wirers about an inch away from the conector and pulled bottaboom bottabing in and out done in ten minutes. Never did take it back and try to claim warranty on the one i bought a few months ago would have fet good to take it to the man
