2001 f150 5.4 wont start
If the theft light is flashing and the odometer is all dashes, and he's tried starting fluid, giving it gas won't do anything. This is an electrical issue.
Have you tried your 2nd key?
Check this thread in the V6 forum:
https://www.f150online.com/forums/v6...-no-start.html
Also check this one in the Lightning forum:
https://www.f150online.com/forums/li...ll-dashes.html
flashing theft and all dashes on odometer
found out the PCM relay and fuel pump relay are the same, replaced fuel pump relay first, no joy then the pcm relay and it works fine
Fixed it!!!
found out the PCM relay and fuel pump relay are the same, replaced fuel pump relay first, no joy then I replaced the pcm relay and it works fine, you MUST try this before letting the dealer replace the PCM ($700 +)
Thanks for all the Help!!!!!!
