Need starter wiring help
This is a replacement starter from 3 years ago as the first was so corroded that that solenoid casing broke trying to take the wires off on the side of the road.
Evidently the nut holding the small red wire came off or corroded off and the braided wire connector definetely corroded off at the connector.
Ground on frame looks good and the battery is fully charged and new.
Truck wouldn't start yesterday so I pushed it in the garage, jacked it up and found what I described in first post.
If you have a factory replacement and remember where you got the last one, chances are you can get a free one if it breaks again. AND if you purchased a Bosch replacement. They keep the info on file.
I just learned that not to long ago. I brought the starter back a few years later - NO RECEIPT and walked out with a new one. Free.
If it's real bad - Take it back, they have your info in the system.
Here's what's left of the TSB I have here lol -
New Starter -
I half azz hooked up the braided wire to the post without a connector end and the starter passed the test at autozone.
Checked it twice to make sure.
I also found a local Grand Rapids rebuild shop that had these starters for 65.00 with 1 year warranty with exchange.
Anyone needing a starter thats not covered under the warranty and lives in a metro area could probably save a few bucks with a phone call or two.
