Stumble in OD
Old Feb 8, 2009 | 11:52 PM
  #46
jethat's Avatar
Originally Posted by hillbilly4u
Another problem I think. Anyone know why the engine will jump from 800 to 12 or 13 revs briefly before going into reverse? Causes a clunk in the drivetrain when it does this. My other Fords didn't do it although they weren't this generation. Gotta cause wear in the joints after a while.
Clean or replace the IAC
Old Feb 9, 2009 | 12:08 AM
  #47
hillbilly4u's Avatar
Thanks. Will try that.
Old Feb 9, 2009 | 01:03 AM
  #48
jbrew's Avatar
Man, I wish my U-Joints would go - So I could some greasers in there
Almost 260 thousand on my stockers - Ford did something right, but always hated the fact that I only have two zerks on the whole truck.
Old Feb 10, 2009 | 08:34 PM
  #49
Was a really nice day here so I thought I would tackle the IAC clean. Decided to just pull the whole throttle body and do it all. Was an easy job after reading the how to section. The IAC looked clean, like almost new. The rest was dirty but not that bad. Just a thin layer of carbon. Cleaned up well. The problem with the jump in rpm's shifting to reverse is the same. Does it worse when cold. Warm idle is at 750. Cold at 800. When shifting to reverse or drive cold, it will idle up briefly to 1200 causing a rough jump into gear. Still the IAC? Anything else could cause this before I buy a new IAC? TPS?
Old Feb 11, 2009 | 01:03 AM
  #50
Any Ideas?
Old Feb 11, 2009 | 10:18 AM
  #51
Bump
Old Feb 11, 2009 | 11:12 AM
  #52
jbrew's Avatar
When cleaning the IAC - Did you work the mechanicals inside the sensor ?
Have you cleaned the MAF ?
Have you suck tested the EGR valve?
Old Feb 11, 2009 | 07:55 PM
  #53
Yes, looked clean and free
Yes with maf cleaner
No, it did have a thin film but cleaned up good. Don't have a vacuum pump.
Old Feb 11, 2009 | 08:02 PM
  #54
jbrew's Avatar
I didn't ask how it looked lol
Well, alright.
You don't need one.
I don't know then, never heard of that problem- Idles way up between gears, then slams into reverse ? Somethings wrong - No idea here :o
Old Feb 11, 2009 | 09:11 PM
  #55
Well, alright.
You don't need one.
I took a small bottle brush and cleaned it good. Eased up on the bottom of the spring and it looked to be moving free is what I meant but didn't say. Sorry for short explanation.
Shift from park to reverse or drive. Will not idle up till I hit a gear, then it idles up before going into gear. Will do the idle up before it will go into gear. Sorta like a delayed reaction. Best I can explain it. Just a very annoying problem.
