Accidentally pulled wire loose. HELP!
Old Jan 26, 2009 | 04:41 PM
Bear_1961's Avatar
Was replacing my oil pressure switch on my 2000 F150 4.6 engine. When removing the wire from the switch I accidentally pulled another plug loose that was attached to the harness right above the oil pressure switch wire. Cannot find what it was plugged into. It was somewhere above the oil pressure sending unit maybe right around the oil filter/lower radiator hose area. The plug appears to have two wires running into it? Any idea as to what this is and where it plugs in. Any help is greatly appreciated.
Old Jan 26, 2009 | 04:46 PM
Matts ford's Avatar
whats it look like? maybe take a pic and upload it. isnt there a wire somewhere in there that doesnt go to anything?
Old Jan 26, 2009 | 06:35 PM
tjk_in_cny's Avatar
Normally you would have to pull back a locking tab to undo an electrical plug. There are a few cases, but very few that would not have a locking tab. As Matt said, get a dig-cam under there and get some pics. Unless someone on here has the same truck as you and is willing to jump under their truck and take a look, you will need to post a pic.
Old Jan 26, 2009 | 08:13 PM
Camarothatcould's Avatar
probably just the power steering assist. I couldnt get mine plugged back in because of my oil cooler being in the way. I notice no difference, its for low RPM steering assist
Old Jan 27, 2009 | 07:32 AM
DYNOTECH's Avatar
Sounds like the powersteering to me as well. Should be a connector right off the p/s pump that your wire will plug into.
Old Jan 27, 2009 | 11:38 AM
jbrew's Avatar
Yea , probably EVO, you don't have the option, so - no worries.- I have a pic of that from a 99 4six here -
https://www.f150online.com/forums/en...-question.html
