truck wont turn over
Old Jan 18, 2009 | 09:13 PM
df150's Avatar
my dads 2001 f150 4.6 only cranks over a half a turn and then quits. temp has been 20 bleow zero for the last week. has new battery and new starter. he started id thursday a.m. to let it warm up. he went to leave and the truck was off and now has this issue. i am completely lost! any info on where to start would be great!
Old Jan 18, 2009 | 10:16 PM
Tumba's Avatar
wrong thread!
Old Jan 18, 2009 | 11:25 PM
jbrew's Avatar
Doesn't make sense to me - bad battery install or bad battery. Is the battery light on in the dash?
Old Jan 18, 2009 | 11:57 PM
Camarothatcould's Avatar
coolant froze, block cracked, leaked coolant into crankcase or cylinder, cause hydraulic lock. . . . .
WORSE case scenario. . . haha
Old Jan 19, 2009 | 09:19 AM
JMC's Avatar
JMC
25 Year Member
How many times can you repeat this start ¼ turn thing in a row? If something mechanical is interfering with the movement of the pistons you should only be able to do it once. If you can repeat the procedure many times you may have an electrical or starter issue. Why was the starter and battery changed? Who changed it?
