Problem
Old Jan 15, 2009 | 08:33 PM
Ryan Sullivan's Avatar
nope i dont have a heritage and yeah i have a k&n put it on the same time as the edge
Old Jan 15, 2009 | 09:18 PM
bjp207's Avatar
probly running lean then, take off the k&n or get a custom tune or youll do some serious damage
Old Jan 15, 2009 | 10:55 PM
why would the k&n change anything?
Old Jan 15, 2009 | 10:58 PM
also how would an edge programmer make it run lean jw sorry i dont no alot about that stuff
Old Jan 16, 2009 | 02:04 AM
jbrew's Avatar
You don't listen very well do yuh
Old Jan 16, 2009 | 07:41 AM
i didnt no how to put my information in
Old Jan 16, 2009 | 07:57 AM
Veteran: Army
I'm gonna put this out there nice and simple
you have a 3 valve 5.4 engine, adding a cold air intake is proven way to make your truck run lean, the edge programmer is a canned tuner designed for a stock engine and since you've got the CAI and the edge you may have ruined your engine.
remove the CAI before you drive the truck anymore and do not reinstall it until you have a custom tune
Old Jan 16, 2009 | 09:15 AM
well that sucks thanks guys for the help.
Old Jan 16, 2009 | 09:36 AM
i was reading on some forums about the edge and people were talking about doing custom tunes with it , can you?
Old Jan 16, 2009 | 09:46 AM
People get confused with their terminology. You can do custom settings of things such as tire size, fuel ratio, timing, shift points, shift pressure, and a few more, but not real custom tuning. The Edge can not be custom tuned so it stays in compliance with California law. To get your Edge custom tuned, you send it to PHP and convert it to a Gryphon, then Bill can custom tune it. He can tune it to take advantage of your K&N CAI. Check them out at www.powerhungryperformance.com.
Old Jan 16, 2009 | 10:14 AM
oh ok thats what i was thinking because i no you can do gear ratio and such but ok i will deffinetly check that out because i do not want to take off my intake for some reason it was a pain to put on haha
Old Jan 16, 2009 | 09:24 PM
bjp207's Avatar
I would take it off before you ruin your engine, the k&n is notorious for running scary lean...you could really mess it up
Old Jan 16, 2009 | 10:12 PM
jbrew's Avatar
Can't he fix that thru tuning ? I hope so, because I'm running scary lean at the moment and hoping that I can get it tuned in. That would suck having to take all the mods off and returning to stock. That doesn't sound right.
Do you mean take it off until your tuned for it maybe?
Old Jan 16, 2009 | 10:32 PM
theres one thing i dont get ok a K&n makes your truck run lean but there are alot of people out there with a k&n that dont have a custom tune.
Old Jan 16, 2009 | 10:53 PM
jbrew's Avatar
It's a 3 valve problem mostly - specially the first year 3 valves which is what you have (I think? No info!!) "Drive by wire systems" - There very picky and I'm surprised your not throwing codes.
Change it back to stock - If your lucky , it's not to late. I'm serious. That motor has to be tuned to set your trims right - per modification..You should always talk directly to a tuner before hand, they will say the same and set you up right.
Those 5fours 2004 + are under tuned from the factory IMO. - Even canned tunes can do those motors a world of good. I've beat stock 3 valves, but my a$$ is handed to me when their tuned/running an intake and exhaust. It's a different truck when their dialed in right.
