Manually Cranking Engine on 97
Old Dec 28, 2008 | 03:37 PM
photoprofessor's Avatar
Dipstick checks o.k. (not milky)
Engine did not lose power or smoke (also no burning smell when truck stopped).
I too four of the plugs out when attempting to turn.
With this being a 97, would it just about the same to replace the engine or the entire truck?
Old Dec 28, 2008 | 03:41 PM
Tumba's Avatar
Glc is here he probably has some good answers.
Old Dec 28, 2008 | 04:08 PM
Being new to this site, can you clue me in to what that means?
Old Dec 28, 2008 | 04:15 PM
Tumba's Avatar
He made the last post on the first page.
He asked which engine.
He is knoledgalble on htese issues
Old Dec 28, 2008 | 04:31 PM
Originally Posted by glc
Which engine, please?
Sorry that I did not see your post.
It is a 4.6 SOC V8
Thanks!
Old Dec 28, 2008 | 04:37 PM
jethat's Avatar
I think the question was what engine do you have? 4.2 4.6 or 5.4?
It sounds to me like your in a solid seized situation. Trying to get it to turn is a waste of time. Sounds like you have proven its toast. Start looking for another engine.
Old Dec 28, 2008 | 05:04 PM
O.K.
Should I be looking for a full engine replacement or fix what I've got?
Old Dec 28, 2008 | 05:29 PM
If the engine is truly seized, I'd look for a good used engine in the boneyard or get a Jasper rebuilt. Pull the plugs and it should turn over easily with a wrench on the crankshaft pulley bolt.
Reason I asked which engine is - the 97 4.2 V-6 had known gasket problems that lead to a hydrolock.
Old Dec 28, 2008 | 06:19 PM
Tumba's Avatar
With the oil presure drop you descibed, it does sound like it is dead.
Give it a decnt burial.
How many miles did it have?
Old Dec 29, 2008 | 08:50 AM
projectSHO89's Avatar
Before assuming the engine is seized, remove the serpentine belt and check again.
I had my AC compressor clutch seize and it locked the engine up exactly as if the engine itself were seized.
Steve
Old Dec 29, 2008 | 10:36 AM
Steve
Thank you for the suggestion-
Tried it yesterday, didn't work
Old Dec 30, 2008 | 12:02 AM
easyrydaddw's Avatar
dont mean to hijack your thread, but i am having the same problem with my 2003 4.6L v8 triton 4x4. I did buy the truck at an auction as a water damage, and i'm trying a rebuild/restoration. The truck itself is in very good condition, but i am have a time trying to turn the engine manually. I get rotation to a certain point then it is jams, rotate back the other way for a bit and jams again. On starting with the starter (all plugs out) she rolled over for a few bumps of the ignition (a good bit of water shot out the cylinders). I wanted to get a few good turns manually before damaging something. I was thinking about removing the serpentine belt as well to possibly eliminate any other accessory pulley causing the hangup. I really dont want to go the bone yard engine route if i can have this engine rebuilt. Any professional advice or tried and proven experiences to share are appreciated. I also drained all fluids that were contaminated with water (fuel, rear, trans, motor oil).
Old Dec 30, 2008 | 12:45 AM
jethat's Avatar
You should start a new thread. Your in a totally different situation and should bring up a new topic.
