4.6 help !
Old Dec 17, 2008 | 01:49 AM
974.6tritonv889's Avatar
Question 4.6 help !
i started my 97 f150 4.6 triton today in cold weather and after immediatly after start up the truck started makeing a horible whineing noise, i have a leakeing front main seal in my transmission but always check to see if theres fluid in it and there was. so could this be a bearing issue ? the truck did it for about 10 minitz then when it started to warm up it quite any ideas please help.
Old Dec 17, 2008 | 03:35 AM
Soaring's Avatar
Whining noises that quiten down after a warm-up usually indicates a worn bearing. Don't worry about it until it fails. In the meantime, try using an additive.
Old Dec 17, 2008 | 04:02 AM
Klitch's Avatar
have you checked out your waterpump lately?
Old Dec 17, 2008 | 06:33 PM
Cool nope
i sure havnt checked the waterpump but i did figure out today that it is a bearing issue just have to figure out which bearing it is. the truck has 215,000 miles on it so im sure it will be needing one soon, the only thing ive had to get replaced scince ive owned the truck was the ac compressor and lines. its been a damn good truck.
Old Dec 17, 2008 | 06:44 PM
Matts ford's Avatar
you can check the power steering fluid. my pump is noisy all the time but i topped it off a little while ago and it made a little bit of a difference.
Old Dec 18, 2008 | 03:20 AM
Klitch's Avatar
pull the belt off, then spin things by hand. you aughta figure it out right quick that way
Old Dec 18, 2008 | 09:24 PM
DYNOTECH's Avatar
I personally doubt that you have a bearing going and it's making a whining noise. My 97 with the 4.6 has made a whining noise for several years now when its extremely cold out. The noise goes away after a mile or two of driving. I have listened under the hood and it appears it's the power steering pump. I wouldn't worry too much about it. Usually a bearing will make a tapping noise when it starts going south.
Old Dec 19, 2008 | 03:32 AM
Klitch's Avatar
not entirely true, bearings will squeel/howl.
Old Dec 22, 2008 | 03:57 AM
THANKS KLITCH ! its a bearing
Old Dec 22, 2008 | 05:25 AM
Klitch's Avatar
heh which one? i hope u got lucky and its just the tensioner that gave up finally.
btw, no problem, thats why i come around once in a while, to give advice (hoping it helps!)
