detonation on regular and premium gas
Old Dec 18, 2008 | 01:01 AM
openclasspro#11's Avatar
keep listening to idiots
Originally Posted by Quintin
Ignition timing hasn't been adjustable in over ten years on an F-Series gasoline engine truck.
what part of this post didn't you understand?
Old Dec 18, 2008 | 04:37 PM
And if you guys keep calling them "stealers", the techs that actually work for them and monitor this board are a lot less likely to want to help you FREE OF CHARGE.
Old Dec 18, 2008 | 06:25 PM
01lightningsuper's Avatar
Originally Posted by KevinCowtown
You just need to show those IDIOTS at the Dealership how to twist that dang distributor a few degrees to the right... or is it the left? Whatever. And check to see... you might need to change the springs to re-curve the mechanical advance - if your computer doesn't have enough bites it might not compensate for weakened springs. An if'n that don't work, clean your points, check the vacuum secondaries, make sure the choke's not stuck, and rejet the carb.
That ought a'bout do it.
LOL What about the Flux capacitor ???
Old Dec 18, 2008 | 08:04 PM
KevinCowtown's Avatar
Damnit Lightning, that is just rediculous!
If you would pull your head out of your computer printouts for one second, long enough to smell the coffee burning, you would realize that the flux capacitor wasn't installed as a factory option until the '08 model year. Same year they dropped the jimson-saddle out of the sludge-pump.
Sheesh.
