oil change ramps?
Old Dec 8, 2008 | 03:17 AM
  #31
code58's Avatar
Originally Posted by risupercrewman
When I ever used ramps I positioned them at the raised Lip of cement where the driveway comes in contact to the cement of the garage....It holds the ramps well when you drive up on them.....
Excellent idea- I normally used them on the cement driveway or in the garage. I spit those suckers out enough times both going up and down that I decided enough was enough. I only have to jack the car up about 3 pumps on the side opposite the drain plug and as stated, no need to on the truck, which is stock.
Old Dec 9, 2008 | 11:25 AM
  #32
ramblin-wreck's Avatar
*UPDATE*
So I got the ramps built Saturday and changed the oil Sunday with absolutely no problems. To be honest, the ramps worked even better than I had thought. Got the oil changed in the F150 and the Explorer in a little over an hour. Thanks to everyone for the help and insight.
