I need a diagnosis, no OBD
Finally finished my 2weeks of work on the truck. Everything works great, but after test driving for 20 minutes, engine light comes on.
Here's what I did:
1) R&R the tranny, and had it professionally rebuilt. O2 sensors are all connected, but something might've got damaged, even though everything is in good shape.
2) Replaced the exhaust manifolds with some BBK headers. Did have an exhaust leak, but is now completely sealed.
3) EGR tube replaced with custom tube. No leaks. But vacuum lines are connected a little differently, but basically very close.
4) Dip stick tube replaced after being broken off at the block. New tube fits a little loose, so I'm not sure if its taking a low pressure reading on the crankcase.
Any ideas? I'd rather not buy a reader if I can get away with it. Or take it to a stealership for them to diagnose. Guess I could try the voltmeter trick.
Appreciate any help I can get.
Here's what I did:
on
Well, I'd offer advice, but since I'm automatically a crook because I work for a "stealership," I'll defer this to people who are honest and upstanding and willing to help you. <insert massive amounts of sarcasm...*here*>
But while I'm here, I'd like to know what you do for a living, so I can make stupid generalizations about your field.
on
Uh, what happened to the orifice that was in your original EGR tube?
Without that, you'll never get it to work.
Don't take this the wrong way, but do you understand how EGR flow is measured on Ford's system? If not, go to www.motorcraftservice.com and download the OBDII manual for your model year truck. It contains a basic description of how it works.
Steve
Steve
Steve
Steve
Thanks for the ref man!!
Actually we had provisions for reconnecting the tube with the extended flex line, but decided not because of length. So I have the fittings, just have to reconnected/reroute.
