key lock cylinder
Old Jul 25, 2008 | 08:22 PM
Jojosgrandmi's Avatar
key lock cylinder
How do I change out a key lock cylinder. My F150 1995 is sitting in the driveway running. I can't turn it off because the key just turns and turns.
How can I fix it?
Old Jul 25, 2008 | 08:43 PM
Matts ford's Avatar
turn key to on position (even though yours already is), then take a screwdriver or pick and from the bottom of steering column under the key lock cyl. there should be a small hole in the panel, stick it up there to push in a pin then the cyl. just slides right out.
