Burping Sound in intake tube?
Old Mar 17, 2008 | 07:32 PM
tkimrey's Avatar
When the weather is cold outside my truck tends to make a slight burping sound. When it does this it sounds like it comes from the intake tube and does this when I turn on heater/ac/anything really. Does it just about anytime, off of idle, cruising on the highway, any suggestions?
Old Mar 17, 2008 | 07:42 PM
torkum's Avatar
What year truck and size motor do you have?
joshmac4.6's Avatar
I would like to hear it "burp".
Old Mar 18, 2008 | 12:35 PM
tkimrey's Avatar
It's a 2002 with a 4.6. I'm not sure if it's some kind of vacuum or what causing this "burping" sound.
Old Mar 18, 2008 | 01:09 PM
jbrew's Avatar
You sure it's not like a gurgling sound ? Never heard them burp before
Fart , but never burp..:o
Old Mar 18, 2008 | 01:59 PM
tkimrey's Avatar
Nope not a gurgling sound. Every now and then it will make a short "burping" sound wait a little bit and do it again...
Old Mar 18, 2008 | 02:59 PM
DIHLON's Avatar
Mine does it when I switch from defrost to the vents.
Old Mar 19, 2008 | 01:15 PM
tkimrey's Avatar
Well, I put on a new BBk 75mm throttle body today and I no longer have the "burping" sound...strange but it worked...
Old Mar 19, 2008 | 01:22 PM
jeffallred's Avatar
Did the new throttle body come with a new IAC(Idle Air Control) valve. Mine was making the same noise and it turned out to be the IAC.
Old Mar 19, 2008 | 04:10 PM
jbrew's Avatar
Yea , the only deal that makes noises is the IAC on the TB elbow - But it only happens if the IAC in line muffler has been removed (via intake mod). That's what the muffler is for.
BTW - The stock TB is good up to 325 hp. You only need a TB mod when you exceed limits , but then you also need to Modify the MAF sensor to do you any good .
Otherwise you won't see much from that mod - Maybe a little @ high RPMs , buts that about it.
