high mileage oil
high mileage oil
what high mileage oil do you guys recomend the most. i have a 99 f-150 with 191,XXX miles and looking for something to keep it running smooth for even longer, i have always ran a conventional oil and i was just wondering if i should switch to something different??
Originally Posted by Galaxy
As much as I'd love to promote Amsoil, I'd have to say if you have already put this many successful miles on this truck then keep doing what you've been doing.
Ive never seen any evidence to suggest that they are any benefits to be had with using a high-milage oil.
If you wanted to make a switch that would give you better fuel economy, Motorcraft 5w-30 would be a good choice. Its a synthetic blend, so it gives you some of the benefits of a synthetic but its not as expensive as a synthetic. I think it costs something like $2.50 a quart.
However, if you are having good luck with what you have been using, you could stick with it.
Ive got 173,000 miles on my truck with few problems (knock on wood). Most of those miles were ran on Mobil Drive Clean and Mobil Clean 5,000. I recently made the switch to Castrol GTX because it has the highest rating of any conventional oil, but I will likely make the switch either back to Mobil Clean 5,000 or to Motorcraft because of how expensive Castrol is.
Castrol is good stuff though.
Needless to say ,I'm using Valvoline In my 06 as well.
