1997 Battery cable hook up help -QUICKLY!!
Old 03-12-2008, 06:37 PM
darth-bob's Avatar
Ok...I bought OEM cables and im hooking it up but I have an extra Negative
wire and I cant remember where it goes.
ok....both positives go to the starter here and the big negative goes here right?
I have the smaller neg hanging off it now in he picture.
I do have a bracket on the frame rail that the cables run through.
DId the other negative go there??
This is embarassing cause I cant remember.
Help please so I can get this on today.
I dont remember taking anything off that top starter bolt.
THANKS!!!!
Old 03-12-2008, 07:11 PM
tech-doc's Avatar
The pic I have shows 2 wires where you have the 1 ground wire. Honestly, it can attach anywhere that is a good ground source. It is just a great safeguard to have a second in case the 1st fails.
As long as you have a ground connecting the circuit, you are good to go.
Old 03-12-2008, 10:34 PM
ONELOWF's Avatar
It mounts directly to the firewall behind the battery ...look for a green bolt or stud.
Old 03-12-2008, 10:45 PM
jbrew's Avatar
Green=Ground------------------------------------------------------------Red=Positive
Quick Reply: 1997 Battery cable hook up help -QUICKLY!!
