Oil pressure sending unit
Old Feb 26, 2008 | 06:06 PM
Terberta's Avatar
We have a 2000 Mountaineer 4.6 SOHC. I need to replace the sending unit switch. Any idea where it is? I've all over the motor with no luck.
Old Feb 27, 2008 | 08:46 AM
projectSHO89's Avatar
You might want to look closer at your engine, Ford did not put 4.6L into Mounties in 2000. The V-8s were 5.0 SOHC engines. What its the 4th digit of your VIN? The 4.6L was first used in model year 2002 for that chassis.
As a general rule, Ford likes to put the switch near the oil filter. Look near the power steering pump if a 5.0L SOHC.
Steve
Old Feb 27, 2008 | 02:09 PM
Hate to be nitpicky, but the 5.0 is not SOHC, it's the old pushrod 302. If you have a SOHC engine in there, it's the 4.0 V6.
Old Feb 27, 2008 | 08:58 PM
Terberta's Avatar
OK my fault it's a 4.0 SOHC.
Old Feb 28, 2008 | 08:06 AM
Aack..misread the manual. Good catch.
Manual for 4.0 SOHC just says "Left side of engine". That would be the driver's side.
Steve
Old Mar 2, 2008 | 01:34 PM
Rockpick's Avatar
Moderator &
Moved from V6.
