PO301 and PO305
Old Feb 24, 2008 | 11:18 AM
jhedges15's Avatar
PO301 and PO305
About a week ago my truck, a 97 with a 4.6, started to misfire at idle while i was sitting in traffic. the cel came on and started blinking so i took it to advance auto parts and it came back with a misfire on cylinders 1 and 5. i did a tune up with new plugs, coil packs, and wires about 2 months ago. so i went back home and changed the plugs with two old ones and still had a problem. i put the new plugs back in and changed the coil pack and it seemed to fix the problem. This morning while driving home it started to miss again. Theres no code yet.
This could just be coincidence but a few days before this happened i had some troyer underdrive pulleys put on. also each time its done this its been raining outside.
Old Feb 24, 2008 | 11:24 AM
joshmac4.6's Avatar
What kind of plugs did you put in it?
Old Feb 24, 2008 | 11:33 AM
jhedges15's Avatar
motorcraft plugs
oh and someone mentioned to me last week that it could be the ignition module. anyone have any idea about that? i dont really want to change that cuz its a $200 part
Old Feb 24, 2008 | 11:55 AM
joshmac4.6's Avatar
motorcraft plugs
Ignition module? These trucks have no such thing, ignition is controlled by the pcm. Did you keep the old coil packs?
Old Feb 24, 2008 | 02:26 PM
jhedges15's Avatar
thats what i thought but a guy at advance or oreileys showed me a part called i think an ignition control module but i didnt think that was right.
i kept everything from the tune up. i put an old coil pack in and it ran great for the last week. no problems at all and it seemed that my gas mileage even went up (but that could be from the ud pulleys).
im kinda thinking its the wires because i know that the motorcraft plugs are good, ive read on here that global automotive has good products, but i used cheap wires that were msd knock offs i think
Old Feb 24, 2008 | 02:28 PM
joshmac4.6's Avatar
Those could be the problem, did you replace the coils with stock or aftermarket?
Old Feb 24, 2008 | 02:40 PM
Did you use dielectric grease in the wire boots?
Old Feb 24, 2008 | 03:48 PM
jhedges15's Avatar
i replaced the coils with aftermarket ones from global automotive.
i did not use dielectric grease when i first replced them. i had it but i did not no where it needed to go. last week when i changed the plugs to test them, i did on the spark plug side. where exactly do i need to put the grease?
Old Feb 24, 2008 | 03:55 PM
joshmac4.6's Avatar
In the boot, where you did. With aftermarket wires and coils it is hard to tell. do you know who makes the coils?
Old Feb 24, 2008 | 04:13 PM
jhedges15's Avatar
global automotive
heres where i got them from: http://cgi.ebay.com/ebaymotors/NEW-I...3756.m20.l1116
Old Feb 24, 2008 | 04:18 PM
joshmac4.6's Avatar
global automotive
Well with a one year warranty I would call them up and get a new set or a refund if possible. If you have a Ohm meter check the wires, the max spec is 10k ohms per foot, but I don't like anything that high.
Old Feb 24, 2008 | 04:22 PM
jhedges15's Avatar
i sent them a message on friday about exchanging it but they have not gotten back to me yet. they should get back to me in a couple of days
Old Feb 25, 2008 | 10:56 AM
jhedges15's Avatar
well im confused now. i went back out to drive it last night and everything was fine. no misfires at all.
and global automotive sent me a message saying that i need to get it confirmed by a certified mechanic to get the part exchanged
