what is most weight you have pulled with your F150 4X4
The most for mine so far, maybe 6k with no trailer brakes. Truck had 4 pin harness only at the time so I had lights only. Knowing that, I planned braking and following distances alot more obviously. The truck has all necessary stuff now, 7/4 pin plugs and a brake controller for next time but this old truck pulled it very easily. This was my car on a flatbed trailer and that's about the most I ever plan to pull anyways, maybe a Bobcat here and there.
on
My wife's Explorer Sport, about 4700 lbs. I had the 4.6 at the time. It did not like the hills. Third gear 60 mph was all that I could get... Stopping was the most difficult. No brakes but the F-150. It would push the truck a bit. Handling and stopping are the big issues. When the trailer pushes the tow vehicle you can get in trouble. Sort of like the tail wagging the dog.....
JMC
JMC
JMC
JMC
Originally Posted by scott1981
I had no idea these bumpers were so strong. While what you did is insane it's neat to know the truck did it
P.S. Other reason I went slow and easy was no towing package, gotta keep the trans temp down.....
edit: realized the post with the 5700lb weight was for a Bobcat backhoe, not a skid loader, I was a little more insane than I thought.....10-11k? Yikes!
Originally Posted by 01Roush
Bumper says its rated for 5000, but I figured that rating has to be maintained under full acceleration, full braking, maybe collision, etc... so there has to be quite a bit of fudge factor built in. At the time I was thinking around 8000lbs, but later realized it could have been much higher. The post above sounds like he actually knows what a Bobcat weighs (I didn't) so I'll go with his 8700lbs....
on
Originally Posted by 2005lariatky
Check your curb weight on the Explorer. You are about 1000lbs high not counting a trailer.
JMC
