1999 F-150 Miss fire (5.4L)
Old Feb 13, 2008 | 09:44 PM
Jshera's Avatar
Alright, so today coming home from work in traffic my truck started to shake it self to pieces. The Check Engine light started to blink so I pulled over. I have dual exhaust and on the drivers side it was popping out of it, not a loud backfire but just sort of a pop. It was also smelling really rich. Now, The common things if read are either Spark Plug,COP,Fuel Injector causing the miss fire. My guess is a fuel injector is stuck open, but I cant get the code read until Friday. Anybody else have any other possible causes?
Old Feb 13, 2008 | 09:47 PM
alsupercab's Avatar
mine too started this 2 days ago. I think my plugs are going bad, but I'd like to hear what someone else has to say.
Old Feb 13, 2008 | 10:59 PM
jbrew's Avatar
Get the code read - Replace the bad Coil. - Done
Old Feb 13, 2008 | 11:00 PM
alsupercab's Avatar
my light isn't on, it just blinked and went off.
Old Feb 13, 2008 | 11:08 PM
jbrew's Avatar
That's okay , it doesn't have to be on. Blink = Code Pending . Off = Code stored. So , see which 300 series code you have Friday and fix it .
Old Feb 13, 2008 | 11:30 PM
Jshera's Avatar
So its more then likely not something serious. I was pretty dam scared when it happened, but after some research its most like a coil, spark plug or fuel injector.
Old Feb 13, 2008 | 11:43 PM
jbrew's Avatar
Nah ,it's a coil, not to serious yet, but get it fixed ASAP before it fails totally. They usually have them in stock.
Old Feb 14, 2008 | 12:02 PM
alsupercab's Avatar
no joke, it feels like the whole truck is going to shake apart
Old Feb 14, 2008 | 12:20 PM
hawg_man's Avatar
I just went through this. Mine was p302 - Misfire Cylinder 2. Replaced Coil and Plug and it runs like a champ again. Luckily it was #2, really easy to go to comparatively.
Old Feb 14, 2008 | 10:47 PM
alsupercab's Avatar
Bad news, I went to autozone to get the code pulled, and it didn't have any...now what?
Old Feb 15, 2008 | 12:03 AM
minimonster17's Avatar
well, a stealership's tool will read codes that autozone's/ advance auto's won't. that being said, there is a way to tell if your truck is storing codes without a tool. before cranking your truck with the key in the off position, hold down the trip odometer button. while holding it down start truck, and hold for 10-15 sec, or until odometer goes into test mode. the first will be a gauge sweep, among others. scroll through them by pushing the trip odom button till you get to the one that reads: dtc:xxxx. xxxx being your stored code. if there are none, the truck will read dtc:none. turn truck off to deactivate test mode, or it will deactivate upon the end of your drive cycle when you turn the truck off. however, i am unsure if this procedure will work on all 97-03's. i KNOW for a fact it will work on the later ones, though.
Old Feb 15, 2008 | 09:42 AM
jbrew's Avatar
I thought you said you had a blinking light, before it shut off ? - Huh - Did you happen to notice how long it blinked before the CEL turned off all together?
3 , 4 , 8 blinks - LOL - I guess I could just ask this - Did the Check Engine Light blink more that once ?
Old Feb 15, 2008 | 05:36 PM
Jshera's Avatar
Guys I need your help. Read the first post for the story if you dont have it.
Well I went to get the code read, and it was a cylinder 8 missfire. So I bought a coil. Went home, replaced it. And had a brand new spark plug so I threw that in there aswell. And Its still miss firing. What else can be causing the 8th Cylinder miss fire. Its a new Coil and spark plug
Old Feb 15, 2008 | 05:56 PM
98Lariet4x4's Avatar
Put a long handled screw driver and listen to the fuel injectors. you should be able to hear clicking. Try 2 or 3 different ones then to listen to #8. If it's not clicking, it's bad.
Old Feb 15, 2008 | 08:05 PM
Jshera's Avatar
Also where do I put the dielectric grease when installing the coils. Inside whre the spring is?
