'89 F-150 Turning over, not starting?
Old 02-10-2008, 12:35 PM
kd7skx's Avatar
Hi all, My good old truck is acting up. I went out to start it today and it just turns over and will not start. It ran last night. A couple of days ago it started up a little rough, sounded like it was missing on a cylinder both when idling and underload. But that went away the next day. Any ideas?
Old 02-10-2008, 01:00 PM
masseyman's Avatar
First check to see if you have spark through the spark plug wires. If you don't, most likely it's the ignition module on the side of the distributor. You need a special tool to remove and reinstall the ignition module.
Old 02-10-2008, 08:18 PM
Matts ford's Avatar
you need fuel spark and compression for it to run so check it all.
Old 02-12-2008, 01:52 AM
kd7skx's Avatar
Just a quick thought and question, where are the relays for the fuel, start up, any thing related basically that starts the truck. Thanks
Old 02-12-2008, 02:25 AM
kd7skx's Avatar
Ok so I just went out and found the relays under the hood. They were covered in snow. So I am going to leave them in the house to warm up over night and see what they do in the morning. I have a bad gap in my hood where snow or what ever can get in too. Had a slight meeting with a guard rail a month back. I will post back with my results in the morning.
Old 02-12-2008, 11:43 AM
kd7skx's Avatar
IT'S FIXED. The fuel pump relay was frozen. It runs great now. Thanks for all the advice. You guys are a great help. I will defiantly stop by again if I need help.
Quick Reply: '89 F-150 Turning over, not starting?
