Spark Plugs and nickel anti-seize
Originally Posted by 04larry
The TSB you posted is what the dealer's tech showed me. He did the procedure that way, but the video specifically says to have it warm.
Ford is going to lose a lot of customers over this if they don't do something about it. If they screw me, I will never buy another one and I have been buying Fords for 30 years and have bought 12 of them from the same dealer. If they screw me, not only will I not buy one, I will sue.
Anyone with this truck and 5.4 liter 3 valve engine should change plugs immediately and make sure they put anti sieze compound on the plugs they put in! Change your plugs often! It will be cheaper and less hassle than dealing with this problem!
I'll let you all know what happens when i get my truck back. I want to see the ceramics from the plugs they took out and make sure crap didn't get in my engine!
Good advice on the anti seize. Apparently village ford in dearborn charges 216 bucks for a spark plug change. They say they've only broken one plug so far. lol. Wait until the '04 trucks roll in with 100,000 miles on em. They'll break a few then!
This video shows a good way to get out stubborn plugs, although they have the heads off, they say its supposed to be done on the truck with the heads installed.
www.flatratetech.com/index.php?categoryid=4
04larry, I'm impressed that they were able to get all the plugs/fragments out without actually having to remove the heads. This gives me a little encouragement that Ford is working on something to help get the broken ones out. Not breaking the plugs is not going to be the issue(because what's done is done and the darn things are in there). What needs to be done, if nothing else, is making a way to get the fragments out consistently without having to have the heads removed. Also, Ford should help the dealers with the cost so we don't have to pay excessive chargers for something that is a definite design problem. I'm just glad to hear somebody didn't get the shaft completely by FMC.
Supposedly, it should be ok now. The big danger of course, is getting either pieces of ceramic or shavings from the threads cut into the metal jacket down in the cylinder where it could cause severe damage.
The video shows them putting grease on the tool that cuts the threads and being very careful with it to prevent shavings from falling down in there.
Ford really needs to do something about this before they lose a lot of customers who have been very loyal, like myself.
What really made me mad was the attitude of Ford's customer service reps who answered the phone and then argued with me and gave me crap and wouldn't let me talk to their supervisors without me just getting obnoxious with them. i was supposed to get a call back from a supervisor's supervisor withing 48 hours and still haven't been contacted.
If the dealer hadn't called and brought up the issue with Ford I would have been out of luck.
Luckily for me, the dealer had enough business sense to know he had a good customer and ended up helping.
I would have considered taking out an ad in the metro Detroit newspaper telling about this situation had I not received help and also would have gone to a lawyer. Ford needs to be better with their customer relations or there won't be a Ford company anymore because they will lose so many longstanding customers.
My father in law worked for them for 43 years and this just takes the cake!
Also, the TSB I posted above states specifically to do it COLD. The original TSB also said to do it cold. Regardless of what this 2-year-old video says, I'm providing the latest and greatest info right from the horse's mouth. (Notice the revision date is early last month)
-Joe
Originally Posted by GIJoeCam
Forgot to mention: Also note that the recommended penetrant has been changed. They no longer recommend using Aero-Kroil.
-Joe
-Joe
What do they recommend then?
Randy
-Joe
-Joe
Is there a new TSB? Where did you read about a new penetrant?
04Larry,
you dodged a bullet!!
$250 for all that work is a steal. I hope they threw in a free timing chain while they had the front of the motor off. If they haven't reassembled it, you should get it done now. Anyone know the receommended mileage to have the timing chain replaced?
The video is also almost two years old. They've done quite a bit more R&D on the issue since then. The prototype too was being tested here in our lab almost a year and a half ago. We were evaluating different adhesives for use in getting the broken ceramic out of the ground shield bore. I'm surprised it's still a prototype too and isn't available through Rotunda yet...
-Joe
-Joe
It is still a lot of work, but does not necessitate pulling the heads.
The tech said he's almost done changing my oil, rotating my tires, and changing my coolant. I should get the truck back this afternoon!
My tech says this is the first one they've had this big a problem with. But then how many 04s have 100,000 on them already? I'll keep my fingers crossed and hope for the best!
Originally Posted by bubbajoe28
04Larry,
I have no idea on the timing chain replacement interval.
GIJOE,
Originally Posted by OVER_KILL
Joe,
Randy
Randy
Using Motorcraft® Carburetor Tune-Up Cleaner, fill the spark plug well just above where the jamb nut hex sits (1/2 - 3/4 teaspoon). A minimum period of 15 minutes of soak time is required. The cleaner will wick down to the ground electrode shield and soften the carbon deposits in this time. DO NOT WORK the spark plug back and forth at this point.
NOTE: COMPLETELY REVIEW THE PRODUCT LABEL FOR THE MOTORCRAFT CARBURETOR TUNE-UP CLEANER PRODUCT - USE AT ROOM TEMPERATURE AND SHAKE WELL.
CAUTION: EXCESSIVE MOTORCRAFT® CARBURETOR TUNE-UP CLEANER, OR REPEATING THE PROCESS SEVERAL TIMES WITH TOO MUCH CLEANER FLUID, COULD INTRODUCE ENOUGH LIQUID VOLUME TO HYDRO-LOCK THE ENGINE.
I've used anti-sieze on dyno exhaust systems where the pipes turned cherry red over and over and had no problem removing threaded fasteners that had run for thousands of hours and they were grade 5 steel.
My 04 Lariat is in the dealers service bay right now with a big problem getting the plugs out. it has 101,000 on it and the manufacturer's recommended replacement of the plugs is 100,000. Took it in for something else and said to change the plugs while they were at it. The first two broke. The dealer used a special tool from Ford to chip out the porcelain way downdeep in the plug wells and then used an extractor to get the first one out. Then the second one broke as well. Dealer wants to charge me way more for my plug change than he quoted me. Ford customer service reps argued with me even the surpervisors, and were no help at all. Dealer has contacted Ford who said to change out the plugs and see how bad it is. Dealer said they may have to take the cab off the frame to change the plugs. i'VE BEEN BUYING FORDS FOR 30 YEARS, BUT NOW i THINK I'VE HAD IT WITH THEM! It is the recommended time for replacement, but every plug is breaking and is taking like an hour just to change one plug. They used the TSB and put penetrating oil in the plugs , but it isn't working. I am soooooo mad! If you have one of these trucks change your plugs way before the recommended time to save yourself a lot of trouble and money!
