Catapillar does F150 Diesel studt
Catapillar does F150 Diesel study
In 1999 Caterpillar did an independent study in which they introduced a 3.0L V6 CIDI to the F150 platform.
http://www.osti.gov/bridge/servlets/...ive/771077.pdf
This is a fantastic white paper that is short and worth reading. The bottom line for me is this, when the new F150 Diesel is available, I am taking on a car note.
I had trouble with the link, too. I had to try a few browser and PDF reader combinations before I got it. When I did, I re-saved the doc as a PDF and put it here:
http://redinkmagazine.net/tmp/CatF150Diesel.pdf
You should be able to open this one.
-Ed
-Ed
CAT isn't going to be the engine supplier and a whole lot has changed so far as emissions regulations since 1999.
I will be seriously surprised if they hit a 50% increase in fuel economy over the current gas offerings.
-Ed
-Ed
Thanks , yea that works
Other threads
Originally Posted by quackrstackr
What was it about that white paper that makes you want to jump all over an 2010 diesel? That simply outlines the case for the study, not any results.
regards....
Right now the PROJECTED #'s for the V6 diesel is around 400 HP and close to the 450 mark on torque .. That's the twin turbo of course - and the one I'm holding out for
regards....
Where have you found specs and EPA estimates for an engine that is not all of the way through the development phase yet? Are you speaking of the rating for the engine that the coming engine is rumored to be based upon?
Just curious, not looking to start an argument.
Wow, can you imagine? If they actually put a diesel that produces more HP and better fuel economy of that of a V8, you might see the death of the V8 in the F150. Even with the higher diesel fuel and more cost per unit.
Interesting?
Interesting?
You and the other "frequent contributors" have helped me out so many times without knowing it (I use the "Search" feature frequently) so I'm happy to be able to do a little something in return.
The wife and I once tried to add up the value of the repairs and maintenance I've done since I bought my truck in Nov 2006 w/89K on it. We lost track somewhere over $2,500.
I'll leave that pdf there for a few weeks in case anyone else needs it.
Now back to our thread . . .
Ed
right back at ya. If the OP needs a copy of the 2000 F150 Owners Manual in PDF format
Edit: <SNIP>
Whoops. Meant to post this in "Can't pull codes from truck."
Right now the PROJECTED #'s for the V6 diesel is around 400 HP and close to the 500 mark on torque .. That's the twin turbo of course - and the one I'm holding out for
