shift kit questions
Old Dec 25, 2007 | 07:00 PM
king ranch's Avatar
shift kit questions
i was wondering if anyone could give me any detailed info on shift kits for a 2001 5.4l 2wd f150 supercrew
i have a edge now in my truck and customized the shifting of my truck but i was wondering is there a point in getting a shift kit if i have a edge and if i did get a shift kit would i change the edge shift times back to stock and let the skift kit do the work or what
thanks
Old Dec 25, 2007 | 10:35 PM
king ranch's Avatar
anyone??
Old Dec 26, 2007 | 07:55 AM
KEITHHATTER's Avatar
My advise would be, POST THIS IN THE TRANNY FORUM or the LIGHTNING FORUM. Happy New Year!
Old Jun 26, 2008 | 05:50 AM
king ranch's Avatar
anyone
Old Jun 26, 2008 | 07:53 AM
phil6608's Avatar
If you put a shift kit in.You will need to put your stock settings back in for the tranny!
Phil
Old Jun 26, 2008 | 03:08 PM
ecm747x's Avatar
What would you be doing with the truck? If you are happy with what the Edge has done, I wouldn't worry about putting a shift kit in unless you have a lot of HP going into the tranny.
The choice is yours. I would ask if the money is worth the performance and is it warranted. As Phil6608 mentioned, if you do put one in make sure you change everything back to stock as far as the tranny goes with the Edge.
Old Jun 26, 2008 | 03:15 PM
Veteran: Army
go for the factory tech C-plate from Mike Dunn, it's great
and yes you'll have to re tune it for the stock shifting firmness in the tune or else it'll give you whiplash
Old Jun 26, 2008 | 03:33 PM
derrick929's Avatar
Yes, I would agree, go with the Factory Tech plate and put shifts back like they were. It will be just fine as far as firmness goes. Now if you want the shift points higher, you may want to adjust that, but the shifts will be definitely firm and quick with the Factory Tech Plate. I like mine.....just read up on it. Theres one stock spring you put back in or it will be too hard of a shift. I did that and mine is perfect with that stock spring used.
Old Jun 26, 2008 | 06:56 PM
king ranch's Avatar
will i notice any difference in power and acceleration
Old Jun 27, 2008 | 10:29 AM
derrick929's Avatar
A shift kit isn't going to add any HP, so you won't notice an increase in power, but you will notice your transmission does not drag with those slow mushy shifts. When it changes, you'll know it goes into gear and it may feel like its accelerating better because it shifts faster and goes into gear rather than dragging on forever. It will be a seat of the pants gain, not an actual gain. It will feel better because the shifts are firm, and not like your riding the cluth so to speak.
