throttle position sensor
Old Dec 23, 2007 | 07:21 PM
Kevin24's Avatar
Hey Guys this is the thread i used for adjusting my TPS. Also jbrew if your TPS has bushings it can still be drilled out.
read this..... https://www.f150online.com/forums/sh...abolt+throttle
Old Dec 23, 2007 | 07:34 PM
jbrew's Avatar
Okay , yea , I had to get one from Auto Zone once during a 600 mile trip when my stocker went out on me down the e-way. Damn thing was down shifting into second @ 80 mph . I hit the next exit and picked one up from Auto Zone and there's didn't have bushings - but it still works
Old Dec 23, 2007 | 10:15 PM
NYfordguy's Avatar
Alright guys ill give her a go!
Old Dec 23, 2007 | 11:47 PM
ScrewedUPF150's Avatar
I have never done this mod because I have not been able to loosen the screws on the TPS. Guess I will go to Sears tor some tools.
Old Dec 23, 2007 | 11:52 PM
jbrew's Avatar
It takes an impact - It even says to use one in one of the manuals, I forget which one.
But ,yea , A little cordless impact does the trick..
Old Dec 24, 2007 | 09:05 AM
NYfordguy's Avatar
Is are you supposed to get a bite on the lower screw with the impact then? I had a hard time getting a halfway decent one with the screwdriver!?
Old Dec 24, 2007 | 09:51 AM
jbrew's Avatar
There's an opening approximately 7-8 inches out from said screw. Using the proper length bit while inverted, lower cordless torque driver into opening. Insert bit end into screw head.. Hit rewind
Old Dec 24, 2007 | 11:15 AM
NYfordguy's Avatar
Danke!
ONELOWF's Avatar
^^^^^^^^^^^ Works for me. Check to make sure that the philips tip that you use is a perfect fit. There a many sizes including reduced clearance types that will make stripping nearly impossible.
Old Dec 24, 2007 | 12:31 PM
jbrew's Avatar
Yea, I'll tell yuh, I have quite a few high end drill/hammer drill motors and just one cheap little cordless Ryobi Impact that's about 3 years old. I use that little impact gun for just about everything besides drilling.
My TPS Phillips head bolts aren't in the best shape from attempts made in the past with screwdrivers, trying to break them loose. Since I've used that impact on them , haven't had a problem.. Handy little gun
BTW - I think there only like $30 at the Home Depot. :santa:
Old Dec 24, 2007 | 02:47 PM
NYfordguy's Avatar
Speaking of mangled screws can you get replacements at the hardware store? Or are these dealer only?
Old Dec 24, 2007 | 04:07 PM
jbrew's Avatar
It's worth a shot. From what I remember , the hardware doesn't carry much in metric.
Old Dec 25, 2007 | 08:23 AM
jbrew's Avatar
Wellllll - did you do it?? I just went out and stuck the meter on mine . It's almost 1.02 - DANGGG. I have to drill it out or use a knurler - maybe a little 1/4 " carbide.
What did yours read?
Old Dec 25, 2007 | 10:43 AM
JMC's Avatar
JMC
25 Year Member
The consensus is that the max reading that you want is .99v. Poke a paper clip through the back of middle terminal of the TPS and connect it to the + lead of the multi-meter. Connect the - to any ground. Take your readings. FWIW the PCm learns what the last voltage was at idle and uses that as a base. So adjusting the TPS seems like a waste of time.
JMC
Old Dec 25, 2007 | 02:41 PM
jbrew's Avatar
Well , Idunno - Might as well get down to .99 - it won't take that long . I loaded up the drill motor with a Rat Tail File about the same size as the hole - Yea , didn't take long. I replaced the screw head bolts with 7mm - Same thread as the COP ear bolts..
Got it down to .99 and tightened her up - Idle went up to 850 rpms - Soooo , I rebooted and it's down to 800 now . That's unusual for this truck . When re-connecting the battery after a long period of time (I disconnect both sides always) it didn't take long to find 700rpms @ idle..
I guess I'll see what happens , haven't went anywhere with it yet..
