help please
Old Nov 2, 2007 | 08:01 PM
capt.scott's Avatar
help please
How to tell if I have bad coils on my 2002 f150 supercrew with a 5.4 engine.
Thanks.
Old Nov 2, 2007 | 08:02 PM
built54's Avatar
if its missing, cutting out, etc... what are you experiencing?
Old Nov 2, 2007 | 08:09 PM
capt.scott's Avatar
It shutters when it is in overdrive around 45-50 MPH and also hesitates when you first give it gas. Also some times when I start it the RPM and the Speedo max out and then come back to normal.
Old Nov 2, 2007 | 08:22 PM
F151's Avatar
The shudder at 45mph could be related to tired tranny fluid. My 2000 did this and a flush and fill cured it.. (at about 70k miles).
And isn't the gauge "sweep" normal?
Old Nov 2, 2007 | 08:26 PM
Shuddering in OD at those speeds can either be the tranny or a low grade misfire. Have you ever gotten a CEL? If so, go over to Autozone and get the codes read.
Old Nov 2, 2007 | 08:31 PM
Mo Power's Avatar
I thought that the speedo and tach sweep only when the battery was getting low. Put a voltmeter across your battery terminals and check the voltage.
