new headers
Old Nov 1, 2007 | 10:48 PM
built54's Avatar
i wish i didnt have over $600 in tires on my back axle or id be drifting in a parking lot right now... dry.
Old Nov 1, 2007 | 10:52 PM
Gotts2BMe's Avatar
x2 and mine are less than 3 weeks old
Old Nov 1, 2007 | 10:56 PM
shifty_85's Avatar
built54...if i had over 500HP im sure id be drifting every were. i have 220HP if that. and drifting on snow is a lil better for the rear diff and tires....untill u go from slideing on snow to hitting dry pavment..thats a weird/bad feeling. but i really cant wait for winter now lol. ill have a few vids of me and my truck blowin threw a snowman at like 50.i love haveing 4X2 haha drifting makeing left turns is easyer than makeing right turns..is this because of my limited slip diff??
Old Nov 1, 2007 | 11:17 PM
built54's Avatar
yeah
Old Nov 1, 2007 | 11:19 PM
shifty_85's Avatar
also ive read alot of things u have posted in the differnt threads...is there anything you havnt tryed on your truck or anything you dont know about the F-150?? you seem to be the Google for the F-150 lol.
Old Nov 1, 2007 | 11:22 PM
built54's Avatar
lol well i dont know anything about the hvac
Old Nov 1, 2007 | 11:26 PM
shifty_85's Avatar
whats that? if u dont know anything about it....its not needed/that important lol
Old Nov 1, 2007 | 11:27 PM
built54's Avatar
ac/heater controls lol...
Old Nov 2, 2007 | 11:33 AM
deficientblair's Avatar
with headers like those pacesetter long tubes can it still work with the cat-back exhaust i have on there now? or do i have to modify the exhaust manifold extensively?
Old Nov 2, 2007 | 01:14 PM
Fifty150's Avatar
Now Back To The Headers
I have the 4.2, which is hard enough to get parts for.
Any manufacturer for the headers & cat back system on the 4.2?
Are they "Smog Legal" for California?
Old Nov 2, 2007 | 03:26 PM
shifty_85's Avatar
headers replace the exhuast manifold. and with longtubes you will have to have a custom pipe made to fit those long tubes will not fit on your Stock Y-pipe or any of the stock down pipe. *long tubes pretty much replace the down pip* shorttys bolt right up to the stock down pipe but as Built54 has reasearched and tested shorttys give u 0HP and 0FTlbs. i belive you would have to get some kind of aftermarket cat *if you still want to run cats* or just get an aftermarket muffler. Built54 can explain this better than i can. but the final answer is No longtube headers cannot go to your stock exhuast Cats. shorttys can but they offer no power gain.
Old Nov 3, 2007 | 01:12 AM
hey Built54, could you expand on what shifty was saying? With a new down pipe can I tie into my exhaust system without changing mufflers?
Old Nov 3, 2007 | 01:15 AM
built54's Avatar
after my long tubes, i ran mandrel bent pipe, custom made, and connected it to my muffler. you dont have to change the muffler.
Old Nov 3, 2007 | 04:36 AM
jbrew's Avatar
- I use d my stock Y with Long tubes and High flows - Long tube Pacesetters aren't Flanged , there a straight 3" OD @ the collector ends . - If your keeping your stock REAR cats or running High Flows behind the header - Eliminate the stock front cat/pre cat , you don't need it - weld the rear converter or High flows directly to the headers - It's tight on 4x4 models , they make reducers that fit inside these longtubes as well - Stock 2.5 converter can slide inside the header with an INSIDE header /collector reducer , You can then use your stock Y pipe..
No problem on 2WD models - You have allot more room.
Old Nov 3, 2007 | 10:18 AM
rescueheroe1220's Avatar
thanks i as well am in the exact same boat and am tryin to figure out everything i need, cause i must retain my cats due to emmisions in my state.
