Aftermarket Coil on Plugs (COPs)
Old Oct 28, 2007 | 12:14 PM
Wraithenwolf's Avatar
Angry Aftermarket Coil on Plugs (COPs)
Second problem, aftermarket COPs. Again will keep the sponsor nameless as I am not trying to smear anyone just tring to resolve. Recently purchased the Granatelli COPs. The COPs came several days later and were in a box marked Mustang 03-06. I called and spoke to the sponsor they assured me these were the correct as I described what I received. I told them the box had been opend and non of the paperwork inside said Grantelli. Again they said this was normal and that they physically check each COP before shipping.
Ok Great, next I took the COPs for installation by a trusted shop that is ASE certified. They attempted to put in and explained these were the wrong part and showed me what OEM COP looked like, specifically that the bolt hole and cable connector were in different location from the stock, OEM COP. Thank you, $180 later and they put back in the stock COPs.
Called the Sponsor, explained the situation, was told "they were the right part and would fit and no one makes a quality Aftermarket COP with OEM fit for the F150" and that with some wiring changes these would fit. So as I am not happy about being told of the fittment problems after I have bought them, I asked for a refund due to the fact I cannot put them in and my mechanic cannot put them in, they are in a box marked Mustang , and they are not F150 OEM fit. I was told no they are now considered a used part. Keep in mind that I attempted to put them in at the mechanics and had to remove them due to bad fit before they were ever fired up.
So Sponsor says he will however replace any damaged ones from the shipping. I send them all back and get 3 new ones and the rest shipped back to me. So after all this I am forced to sell them or attempt to install. Has anyone else experienced this and if so what should I do, I can follow direction, just don't know if this sounds right or how to install. thanks.
Old Oct 28, 2007 | 12:22 PM
phil6608's Avatar
The best thing I can tell you is to resell them!
The Granatelli's are junk anyway!!!
Phil
Old Oct 28, 2007 | 12:25 PM
Thanks hindsight 20/20 will do. wanted to maximize bolt ons. But, with 45K haven't had any problems with the stock COPs yet. I had heard they were junk, however and need to be replaced, the earlier the better.
Old Oct 28, 2007 | 03:49 PM
JMC's Avatar
JMC
25 Year Member
What is the Part Number on the box? Do you have the 4.6 or 5.4 engine? A 3 valve 5.4 doesn't use the same COPs as does the 4.6 2 valve. The 05-08 Mustang has a 3 valve engine and they should fit the 5.4 3 valve.
JMC
Old Oct 28, 2007 | 08:53 PM
phil6608's Avatar
I have a 2V 5.4 and making big power with just the stock COPs. They do go bad sometimes. I have replaced them all once and no problems since!
Phil
Old Oct 28, 2007 | 09:29 PM
Part number is Vendor Part number? GMS-28-1812CP
Label says 2005-2007 COP Connection Kit W/T Performance Coils Mustang GT
I am confident it is for 3 valve 5.4L the issue is the fit is not OEM. And this was not discussed or mentioned when I purchased the product. My stock COPs are 180 degrees between the bolt hole and the connector socket. These aren't and the wires will not reach. My mechanic would not put them in because the wiring harnesses will not reach on the Passenger side I believe. Again the box clearly states that these are for 05-07 Mustang GT and even the vendor admits after the fact that the wire harness must be modified. It was the Vendor/Sponsors oppinion that no one makes a COP for the F150 yet with OEM fit, again after the fact and after he told me he would not refund my money. Sadly they told me they would fit and I attemted to have them installed to no avail. So looks like Ebay. Thanx..
Old Oct 28, 2007 | 09:57 PM
MGDfan's Avatar
Hi.
Perhaps try contacting Granatelli directly and seek independent confirmation - as I can find nothing that suggests any mods are required.
Granatelli's site shows that part number to be applicable to all 3V's. No FYi or tech tip on wiring changes....
Are the part numbers on each coil?
Several folks here are running these COP's - I can't find any posts relating to an install issue either.
Contact info is at the top of this pdf: http://www.granatellimotorsports.com/pdf/manual66.pdf
Old Oct 29, 2007 | 11:40 AM
I will contact them and I did not buy them directly from Granatelli, so maybe there are instructions which should come in the box that I did not get. Thanx..
Old Oct 29, 2007 | 12:00 PM
jbrew's Avatar
IMO - The COP's with the best track record are the OEM's that Global sells. I know of two people around here that I installed them on about a year ago that hasn't had a problem and many on this site that has had good luck with them.
There only $96 for a set of 8!! Warranties for 1 year..
To many problems with after market coils - you'all can have that overpriced junk and good luck with em - It's getting to the point of being very lucky to get 8 good ones in sequence nowahdays ..
EDIT: I don't think Global sells the 3 valve COP's - The best 3 valve COP's to date are the MotoBlues from RPM Outlet (only place you can get them)...
Old Oct 29, 2007 | 12:09 PM
Bootleg837's Avatar
I called Granatelli and they offer me My money back I wish I had taken it now I told them about the wire issue I got the wrong coils right off the bat returned the three that where for the 4V engine then got a call that said I had to return all 8 so I did that. Got the new set boxed up much nicer ,put then on three dead right off the Bat returned 4 of them One box. That was a mouth ago and Have not heard from them , when you get the coils there is nothing on the coil no part # nothing so you don't Know what they sold you
https://www.f150online.com/forums/sh...ght=Granatelli
Old Oct 29, 2007 | 12:17 PM
MGDfan's Avatar
Yeah - saw that one. Aside from the quality issue, I infer from your post that they did indeed fit out of the box, once the ones clearly meant for the 4V's were returned?
Thanks - this is good stuff as I was contemplating these things myself.
I think I just changed my mind, lol.
For that amount of coin, quality should not be an issue.
Old Oct 29, 2007 | 12:34 PM
jbrew's Avatar
Those little quick probes work awesome for checking coils at all loads. You have to run a wire thru the firewall- Clamp probe to coil and monitor the pistol light during the drivecycle - Dead givaway when you have a weak COP and NO MIL..
Old Oct 29, 2007 | 12:36 PM
MGDfan's Avatar
Very cool!
Ol' bubba done learnt sumptin' new!
Old Oct 29, 2007 | 12:37 PM
Originally Posted by MGDfan
Very cool!
I don't believe it! Wow!
Old Oct 29, 2007 | 12:49 PM
jbrew's Avatar
I new something Ol' bubba didn't - Dannngg.. I wonder what else you don't know? Maybe I can pay you back some - you learned me many things in the past buddy, thanx -
