Engine looses power on takeoff
Old Oct 28, 2007 | 10:13 AM
hooverone's Avatar
I have a 1997 expedition xlt with the 5.4 triton with 148,000 miles This has only happened twice yesterday was one of the times I go to take off from a stop sign and the motor acts like power is being robbed from it like it is going to die and then if I let off of the gas the power comes back and it is OK
It is a very wierd feeling not sure what it is, it did it once yestery in about 20 stops and only once in 90 miles I am not sure what is causing it, is there anything I should start to look at?
Old Oct 28, 2007 | 10:17 AM
Pheonixx's Avatar
clean the mass air flow sensor, or replace it. do a search for MAF cleaning and you will see how it works.
Old Oct 28, 2007 | 10:18 AM
Also make sure it is still plugged in... who knows, some vibration might have partially disconnected it.
Old Oct 28, 2007 | 10:55 AM
torkum's Avatar
Could be the beginning of a throttle position sensor problem. Go to AutoZone and have a scan done even if you don't have a check engine light on. There could be a pending code that shows up before the check engine light comes on.
