need info on coil packs
Old Oct 20, 2007 | 01:14 AM
jgipson's Avatar
guys i need some advice on how to change the coil packs on a 2000 5.4.
Old Oct 20, 2007 | 01:27 AM
built54's Avatar
well, there is a small bolt that holds each one on, its a 7 or 8mm, cant remember.
Old Oct 20, 2007 | 01:39 AM
jbrew's Avatar
Here some info - You don't have coil pacs on the 5.4L.. They used coil pacs on the older 4sixes and still use them on the 4.2's.. The 5.4L motors never had them..
There all 7mm bolts that aren't torqued all that tight . COP's need to have movement on the bushings. Otherwise the ears may crack and snap off from vibration.
Heres the specs -
Old Oct 20, 2007 | 01:44 AM
BlackDawg's Avatar
Hmm? Is the coil on plug different than a coil pack? My 5.4 has COP's.
Old Oct 20, 2007 | 01:52 AM
jbrew's Avatar
Yea ,all 5.4L motors have COP's systems - all 4sixes are COP'ed now as well.. - and it's "Coil Over Plug" = (COP) ...
Old Oct 20, 2007 | 08:03 AM
Tumba's Avatar
http://www.fordf150.net/howto/
try this
Old Oct 20, 2007 | 08:36 AM
jbrew's Avatar
Actually , this would help much bettuh -
https://www.f150online.com/forums/li...parkplugs.html
haha
Old Oct 20, 2007 | 10:45 AM
jgipson's Avatar
thanks for the advice on the cop
Old Oct 20, 2007 | 10:56 AM
built54's Avatar
Sorry I thought you had the 5.4
Old Oct 20, 2007 | 05:18 PM
Tumba's Avatar
haha
i;m so good i smell good
Old Oct 20, 2007 | 05:37 PM
jbrew's Avatar
Oh NO - What's this "O Jbrew" Sh_t ? i
Have you been getting into MGD's threads
I think that came about last Thanks Giving - Idunno , maybe not that long ago..
Old Oct 20, 2007 | 07:37 PM
slsrfr4lf's Avatar
I have a 2001 F-150 supercrew with a 5.4 L Triton motor and had a detail guy wash the engine compartment and now have (4) cylinders with a mis fire problem. Anyone have any idea if this problem will fix itself or if the cop's may be bad?
