Please help knocking
Old Oct 9, 2007 | 06:27 AM
davidshick2's Avatar
I can hear this knocking coming from the front passenger side of the motor at idle and its not all the time its off and on and I want to say I dont hear it if the a/c is on. Any input is much appreciated.
Old Oct 9, 2007 | 06:55 AM
Tumba's Avatar
knocking
you didn't specify if it was front or rear of the engine. if it is coming from the front check the idler and tension pully on the fan belt
hope that helps
Old Oct 9, 2007 | 11:58 AM
Which engine?
Old Oct 9, 2007 | 08:02 PM
sorry about that its the 5.4 and in front of the motor around the a/c pully
Thanks again
Old Oct 10, 2007 | 01:55 PM
DYNOTECH's Avatar
As someone else stated. Remove the serpentine belt and run engine a short time. If noise no longer exists with the belt off then check the belt tensioner and all pulleys for defective bearings. Good luck
