Project GO FAST is now in progress!!!
Old May 14, 2009 | 08:00 PM
  #2311
Blown F-150's Avatar
That's too bad. I hope you can get on it sometime soon.
Good luck with getting everything else taken care of!
Old May 15, 2009 | 02:21 AM
  #2312
Veteran: Army
I'm hoping that eliminates all belt slip
Old May 15, 2009 | 08:24 AM
  #2313
built54's Avatar
Im sure all belt slip is eliminated. I put a wrench on the blower pulley, and by turning that wrench, it will turn the engine over, without slipping the belt one bit.
Old May 15, 2009 | 09:33 AM
  #2314
phil6608's Avatar
Looks & sounds good!
Can I ask what size blower pulley & the size of the extra idler pulley is?
Thinking of selling the cog setup and going back to regular type pulleys.If I do I like to get a MP idler bracket.
Phil
Old May 15, 2009 | 01:15 PM
  #2315
That belt sure is a close fit! With that much belt wrap, I would hope you don't see any slippage!
Old May 15, 2009 | 01:50 PM
  #2316
Faster150's Avatar
damn thats a tight belt, hope the input shaft can handle that load on the bearing.
Old May 15, 2009 | 07:08 PM
  #2317
built54's Avatar
Its not that tight, its just a lot of wrap
Old May 15, 2009 | 07:09 PM
  #2318
built54's Avatar
Phil
the blower pulley is 2.75, the top idler is 100mm, and the bottom two are 90's
Old May 15, 2009 | 08:52 PM
  #2319
phil6608's Avatar
Thanks Joe,
so if I run my 2.5 blower pulley ,I should have plenty of clearance for the 100mm top idler.
Phil
Old May 16, 2009 | 01:28 AM
  #2320
built54's Avatar
oh yeah, just a little less than mine. shouldn't slip
Old May 16, 2009 | 04:40 PM
  #2321
Veteran: Army
Phil
good thing you asked as I was about to
Old May 31, 2009 | 09:19 PM
  #2322
150xlt's Avatar
Hows the project coming?
Old Jun 1, 2009 | 01:45 PM
  #2323
built54's Avatar
I actually just got back from an 8 day vacation in florida, so the project continues soon
Old Jun 15, 2009 | 09:55 PM
  #2324
built54's Avatar
well the original "project" is on hold because something else came up with the truck, so this should be done by the weekend, and the original project will continue! My camera isnt uploading pics right now, so im gonna get that figure out and put them up
Old Jun 16, 2009 | 05:05 AM
  #2325
Veteran: Army
oh c'mon
