Wheel well removal
Wheel well removal
My wife wrecked my truck pulling into the MAC machine this weekend when I was away at the Bristol race and it left a nice dent in the front quarter panel. I am going to remove the plastic wheel well cover and TRY to pund the dent out. Is there a trick to removing that plastic cover? It just won't come oof of there!
If your truck is a '97 thru '03 then it's pretty simple.
Like built54 said it's just a few screws, I think it's a total of 5 but I could be wrong on the count.
Now if it is a 4 wheel drive you will have the additional wheel well trim that will have to be lossened or removed.
Really it only needs to be loosed to access the fender liner screws. Just remove all the mount screws for the trim peace. It will stay on as there are all so some clip things holding it. Try not to undo the clips as they are more likely to break than pop loose.
With the trim screws out, there should be anough play that you can reach all the liner screws.
Doug
Doug
