Engine failsafe mode
Sounds like you didn't disconnect the battery first. Something you have to do before putting a wrench to it. Throttle body specers do absolutly nothing for these motors . You got scammed.
You might have fried the PCM if the battery wasn't disconnected.
I don't know what to tell you on the 04. The TB is different on those.
make sure everything is pluged in and reset/reboot the computer.
Didja booger with the throttle body assembly in any way? Move the throttle blade by accident?
Apart from not following the highly recommended 'always disconnect the battery before working on yer engine' mantra, you may have 'de-calibrated' or otherewise peckerated dat thang.
You could try a batt disconnect to clear the KAM in the PCM - but I think in your case you may be lookin' at a dealer visit to service the TB.
BTW - I assume you checked your work and there are no connectors, etc hanging / unsecured.
Finally - one of the great things about a forum like this is it's also a repository for what not to do, as well as all the other benefits. A quick search would have prevented this whole mess, as it would have confirmed that a TB spacer was a useless mod to begin with. Perhaps next time ....?
Good luck.
Bubba
Good luck.
Bubba
