Idles low and dies, runs good w/foot on gas
on
To remove the Alternator you need to remove the air inlet tubing. Did you tighten all the clamps and reinstall the two tubes going into the adapter just in front of the throttle body? Are they loose allowing a leak. Follow them back to the valve cover and the IAC to be sure they did not get knocked off.
JMC
JMC
