My truck loosing its oomf....help
Ok guys let me give you the breakdown. I have put alot of stuff on my truck since i bought it 2 years ago. You can read my signature what ive done. When i first got it it seemed to have plenty of power. I could spin the tires easily and it just felt all there. then i put on all the power accesories and new tires and somewhere alpong the line it seemed to justy dwindle in the power department. I know tires dont help this, but right when i got them on i still felt like i could tear it up more then i can now. like i was stuck in some heavy snow deep and when i gave it gas in 4wheel drive it didnt even turn the tires....it just revved.. feels like it has no ***** anymore. What do you think is causing this? I am going to clean the MAF tomorrow. But does anyone else have any suggestions on what to do? clean something, throw something away whatever....
thanks in advance
btw i have 3.55 ls axles
thanks in advance
Great looking truck The new gears will really wake it up and then I would consider Magnaflow exhaust. Do a search in the Exhaust section on Flowmaster vs. Magnaflow. I was a big Flowmaster fan when I had 5.0 Stangs but they don't seem to give these Tritons what they need like the Magnaflows. Still clean the MAF, that never hurts to do and clean the K&N too!
I think there around 300 greenbacks..Hang on , I'll find the link again..
Here it is -
http://www.rpmoutlet.com/musv8wgf.htm
There only 200 for the 2 valves - that's for all eight !!
They have a better speced material (Primary ,secondary windings) Duel Mag Design.. I Imagine there a little hotter , but that's all you need really with a close to stock motor. So , I'll get me a set ..
Granetelli & ACCEL have been having probs with there - COP's and Coil Packs.... You can really PAY for those headaches... No Thanx..
Here it is -
With that low of mileage i would hold off on COP's for now.I would change the fuel filter,clean your air filter,MAF sensor, new Motorcraft plugs,and if that doesn't do it clean the throttle body and EGR ports
Your plugs were supposed to be changed at 60,000 miles.I would also run some good injector cleaner through it (redline,lucas,chevron)I bet the plugs would help alot if original
