intake manifold
Old Jul 13, 2007 | 05:23 AM
colo_01_150's Avatar
intake manifold
i have a 2001 5.4l super crew, ive been looking for aftermarket intake manifolds or cylinder heads but have found nothing. i want to add HP without adding a supercharger, i have KN CAI, throtle bodie spacer, edelbroch throtle bodie, and pacesetter shorty headers. is there anything else out there?
Old Jul 13, 2007 | 05:36 AM
ditch the throttle body spacer, get a ported/polished plenum. Get or P&P your actual intake manifold. Get a tuner. and get Long Tube headers....
-Patrick
Old Jul 13, 2007 | 05:16 PM
Veteran: Army
get some stage 3 heads and a good set of cams, long tube headers, 23# or 36# injectors with an 80 or 90 mm MAF and a good tune and you'll be screaming compared to what it does now.
ditch the shortie headers and the throttle body spacer ASAP
Old Jul 13, 2007 | 05:28 PM
dubbass33's Avatar
how would one go about doing this?
Old Jul 13, 2007 | 05:33 PM
SlammaJamma's Avatar
I don't think it can be done on a sewing machine...err I mean VW
Just messin w/ya
Old Jul 13, 2007 | 08:04 PM
Faster150's Avatar
find a shop that can do it but it will cost ya. about 250 or more to get it done. ur better off doing it urself.
Old Jul 14, 2007 | 12:22 AM
cant find anything on a 2001 5.4l
were do i find some stage three heads for a 2001 5.4l....looked....nothing.
Old Jul 14, 2007 | 01:40 AM
dubbass33's Avatar
and how would i go about doing it?
Old Jul 14, 2007 | 03:23 AM
take it off, and carefully remove a little material, then hone it smooth
Old Jul 14, 2007 | 11:13 AM
Faster150's Avatar
patriot heads. fox lake. port pros. number of companys sell heads for the modulars but ur looking at about 1200 bucks for a set of heads
Old Jul 14, 2007 | 11:51 AM
Bluegrass's Avatar
The PCM program is the major reason these engines don't run as you think they could.
Ford has retarded the performance in a number of ways and attempting to meet emmissions law and increase the longevity, as a competitive and sales factor .
Besides the truck weight 5500 +.
A 4.6 L motor is only 281 cu/in. Smaller than a 1968 Mustang motor.
The company does these things for their benifit, not yours.
Example: 4r70w trans. It has a low first gear and a high OD gearing. It is to make up for the weight and the low torque of the motors from as far back as the 93 Lincoln Mark series cars that began using these Mod motors.
This motor design is already 14 years old. Once the commitmant is made and some combinations are not the best serving, you are stuck with it untl major changes occurr.
Are you beginning to see the points?
Old Jul 14, 2007 | 04:06 PM
Faster150's Avatar
1991 town car and crown victoria had the first 4.6 modular
Old Jul 14, 2007 | 05:25 PM
Veteran: Army
anything for the 2 valve mustang is what you need since they are the same heads
Old Jul 19, 2007 | 10:34 PM
mikeyss's Avatar
I recently swapped my plastic intake manifold for a 99 aluminum one. I ported it and I feel a noticeable increase of low end torque and feels a bit faster. I also swapped out the stock coils for accel coils. So far I have the intake, a K/N cold air intake, and coils as modifications. I also have been getting 20 mpg with highway driving now.
