Loud Knocking From Throttle Body Area??? Anybody???
I would not use anti-sieze on the threads IMO
Last time i used it and 15,000 miles later 3 plugs were a little loose so i didn't use it this time.I would rather have them sieze a little then a plug blowout
I run NGK V-Power plugs should I change those out you think? I have a 1997 F-150 with a 4.6L I have recently rebuilt it and am having some troubles 99% sure its with the timing I messed up a little when putting it back together its out about 8 degrees. I have a post up already about it called "any thoughts" but anyway, should I cnahge out my NGK plugs for Motocraft ones?
New COP's and New Sp 479's
Ok guys this is the moment of truth
I have received the New COP's in the mail, have new SP 479's, and going to install this afternoon. Will up date to let you know how it comes out.
Fingers crossed.
Fingers crossed.
Man.. he's been out there for an hour..
And an above poster asked about plug brand.. I know peeps all have opinions and mine is Motorcraft all the way. Besides my '07 SuperCrew I have a 94 Stang five litre and have always run MC plugs, sensors, cap and rotor, and Motorsport wires and would never use anything else... Even after I redid the motor at 163k, (you could still see the machine marks on the cylinder walls
) I replaced every sensor and the tune-up stuff with ford parts.
Last edited by SproutsDad329; Jul 12, 2007 at 02:12 PM. Reason: bad typing bc of crappy work keyboard
I changed the COP's and the plugs, got no change in the way it's running or the loud knocking coming from under the throttle body area???
Got any new suggestions???
Maybe I need to describe my problem with more clarity.
I changed the COP's and Plugs, still missing, and the knocking is still there.
The knocking comes in on acceleration at about 1500 rpm and goes away at 2500, then on deceleration comes in at 2500 and goes away at 1500. At idle there is a decernable ticking not Exhaust but like a compression "tick", which sounds more like thht, thht, thht, coming from inside the engine.
We Have An Update!!!!!!!!!
Hey guys checked the Knock Sensor, checked out fine, went to the IAC, looked bad and checked out bad.
Replaced IAC, started truck, knocking persists, looking at EGR, MOTOR MADE THESE SOUNDS bang BANG BANG AND LOCKED UP!!! I figure a wrist pin or a dropped valve.
In any event I owe more than the truck is worth. HMMMM???
What do I do now?
Going to sleep onit!!!
Thanks for all your help, will get back to you later, right now I have a date with Jack Daniels.
What do I do now?
Yeah - He only has 81,000 on the clock !!! Wow!!
Well something went south
Are you the original owner ?
221,000 thousand on my 5.4L and it doesn't skip a beat..
That's some bad luck -
.Mine runs better than when i bought it with 45,000!!!!Fordman the truck looks in really nice shape,its worth putting a motor in IMO!!!!!
